Just finished swap but knocking noise... Help
Old Nov 28, 2005 | 08:20 AM
spreng87's Avatar
Default Just finished swap but knocking noise... Help
I just finished putting my 1995 b18b1 back into my Eg hatch. Now for some reason it has a knocking noise. I'm not sure if it's a valve train knock or whatever... when i had it in the car before it was running clean... now it knocks so what are the possibilities of this.
Old Nov 28, 2005 | 08:25 AM
Kendall's Avatar
Arrange for a valve adjustment somewhere and be sure that the car is completely cold before doing it.
JDM-97CX's Avatar
Default Re: Just finished swap but knocking noise... Help (spreng87)
You are going to have to do better than that. Find out where it is coming from. It could be anything given the information or should I say lack there of that you have provided us with.
Old Nov 28, 2005 | 08:26 AM
JDM-97CX's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Arrange for a valve adjustment somewhere and be sure that the car is completely cold before doing it.</TD></TR></TABLE>
That's a waste of money if it isn't valvetrain. You are a moron, leave.
Old Nov 28, 2005 | 02:50 PM
spreng87's Avatar
Sorry for the lack of info. but it seems like it's coming from the head... i didn't want to put my head too close to the exhaust manifold to actually make sure... it seems like it could be either both head and bottom end. what could the case be? you can hear it very clearly too when it's started. click.... that's the actual noise click click click click... yea so i just want to get to the bottom of this
Old Nov 28, 2005 | 03:01 PM
komat's Avatar
get a big flat head
put the tip at where u want to listen to a sound closely
then put your ear on the handle
use this method to find where extactly the sound is coming from
Old Nov 28, 2005 | 03:03 PM
Heylookits shawn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">
That's a waste of money if it isn't valvetrain. You are a moron, leave.</TD></TR></TABLE>
and you are an ***. you added nothing at all by that post.
to the OP, from what you described it sounds like its the valves. do/have someone do a valve adjustment for you, the tools arent expensive and its not hard to do yourself
Old Nov 28, 2005 | 09:31 PM
spreng87's Avatar
would this be of some help also... while the engine was out of the car... the engine was sitting outside ever since mid october with no headers on? would that be the reason why after i put my engine back into my car it sounded like the valves were tapping? if so then what could it be tapping? the pistons? or the valve seats?
as for the tools. yea i'll do anything for the first time... as long as you got good directions and i have the tools i'll do it myself. I'd rather have myself do it than anyone else...
Old Nov 29, 2005 | 02:01 PM
spreng87's Avatar
so valve work then?
Old Dec 6, 2005 | 03:04 PM
92eg6's Avatar
im having the same problem, and im also guessing the head even though i was told it might be the block, because it sounds like it did when i had the b16 in, now its a gsr w/the same head so i hope its the head
Old Dec 7, 2005 | 03:41 PM
JDM-97CX's Avatar
Default Re: Just finished swap but knocking noise... Help (Heylookits shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">and you are an ***. you added nothing at all by that post.
to the OP, from what you described it sounds like its the valves. do/have someone do a valve adjustment for you, the tools arent expensive and its not hard to do yourself</TD></TR></TABLE>
Actually I did add something you are just too obtuse to realize what it was. I was saving the OP money by telling him not to just go and get a valve adjustment. Think before you post.
And there are several other things it could be besides valves. So don't waste peoples time and money.
Old Dec 8, 2005 | 08:06 AM
theEGkid's Avatar
sure your not hearing injectors ticking?
Old Dec 8, 2005 | 12:09 PM
FalkenSiR's Avatar
Default Re: (theEGkid)
Injectors will never be louder than a valve tick or an engine knock.
Old Dec 9, 2005 | 03:31 PM
JDM-97CX's Avatar
Default Re: (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">Injectors will never be louder than a valve tick or an engine knock.</TD></TR></TABLE>
Untrue. Although it is a rare occurance, once in a great while I see a car at work that sounds like the valves are ticking when in fact it is a faulty injector. All of the ones I have seen had a defect in them from the factory and the vehicles all had less than 100 miles on them.
So yes, 99% of the time they will not be. Being a tech you learn to never say never.
teg racer 877
Oct 13, 2008 03:34 AM
Econo'Box
Apr 5, 2005 08:55 PM
hatchdrvr
May 27, 2004 06:00 PM
Bictorious
Apr 24, 2004 07:04 AM
FMIDRC Racer
13
Oct 20, 2003 07:57 PM
