Winding Noise when I rev, HELP!!! Audio!!!!
Old Nov 28, 2005 | 02:43 AM
Crank's Avatar
Default Winding Noise when I rev, HELP!!! Audio!!!!
I have an Pioneer P6600 indash, After I Installed, It has a annoying winding noise.. Anyone want to help me figure this out. Btw the winding isnt as bad when its at idle, but when I rev the motor or cruise, its all badd..
*EDIT Again*
all grounds has been changed. no difference..
*EDIT*
front/rear speaker's are ampped
1 sub
1 1fared cap
Modified by Crank at 4:41 PM 11/28/2005
Modified by Crank at 4:42 PM 11/28/2005
Old Nov 28, 2005 | 05:08 AM
B18C_EJ8's Avatar
Alternator whine. Possibly caused by a ground loop.
You could try a ground loop isolator and see if that helps.
Are you running an amp on your speakers, or just the deck?
Old Nov 28, 2005 | 08:11 AM
turboHX's Avatar
Default Re: Winding Noise when I rev, HELP!!! Audio!!!! (Crank)
check ur grounds and also u can use as stated b4 ground loop isolator .
Old Nov 28, 2005 | 09:49 AM
92ehatch's Avatar
Default Re: Winding Noise when I rev, HELP!!! Audio!!!! (turboHX)
is the noise coming from the speakers?
if so you might be getting electrical noise.
my car has alternator wine even without my stereo system installed, but when i ran my RCA too close to my power wire it made noise through my speakers
Old Nov 28, 2005 | 02:24 PM
Crank's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Alternator whine. Possibly caused by a ground loop.
Are you running an amp on your speakers, or just the deck?</TD></TR></TABLE>
this might be it, all speaker's are ampped. got 1 sub too. bump!
what is a ground loop isolator?
Old Nov 28, 2005 | 03:40 PM
Crank's Avatar
Default Re: (Crank)
bizzump
Old Nov 28, 2005 | 03:46 PM
Crank's Avatar
Default Re: (Crank)
hmm, i might just get a ground loop.. i think i need 3, since i have 3 outputs.. sub/f/r speakers
Old Nov 28, 2005 | 07:11 PM
romoracing's Avatar
Default Re: (Crank)
are the power wire and rca ran on the same side of the car? if so split them apart.
Old Nov 28, 2005 | 07:40 PM
Crank's Avatar
Default Re: (romoracing)
ill see
Old Nov 29, 2005 | 08:52 PM
boost'd_crx's Avatar
sounds like a ground loop
Old Nov 29, 2005 | 11:35 PM
GSteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romoracing &raquo;</TD></TR><TR><TD CLASS="quote">are the power wire and rca ran on the same side of the car? if so split them apart.</TD></TR></TABLE>
Eh, even if the RCA and power wires are on different side, noise will probably still be there. The car chassis is a great source/conductor of noise. The RCA will pick up noise regardless of where they are positioned. Best thing to do is minimize the noise pick-up with twisted RCA cables.
Old Nov 30, 2005 | 01:04 AM
Crank's Avatar
Default Re: (GSteg)
thanks for the info guys, but i think imma figure this on my own. and yes its a ground loop problem. im going to rewire my whole audio system.
DcLs
Audio / Security / Video
12
Nov 22, 2008 05:58 AM
lemongreenhatch
Jun 5, 2005 09:10 AM
wessieball
Jan 3, 2004 02:02 PM
EKtypeRhaTcH
Dec 12, 2003 10:22 AM
King_j
Sep 25, 2003 12:34 PM
