my fan wont turn on, i read threads, have questions
Old Nov 28, 2005 | 12:28 AM
lv6l's Avatar
Default my fan wont turn on, i read threads, have questions
my fan wont turn on. i turn on my motor left it there and notice my fan is taking a long time to turn on. it work a couple days ago. now dead. i waited and waited outside and look at the fan until i went back in the car and notice my temp gauge was sky high! i turn off the motor. when i turn my heat on full blast, my temp gauge seem to go down, but goes back up when heater is off. my fuse under steering is good, all fuse in engine bay seems to look good. now what?
Old Nov 28, 2005 | 12:39 AM
vancoland's Avatar
take off the plug on your fan and get a line and directly connect it to the battery to see if the fan turns on...if it doesn't then its your radiator fan thats messed up.
Old Nov 28, 2005 | 02:16 AM
The_Todd's Avatar
Farts in the shower
Default Re: my fan wont turn on, i read threads, have questions (lv6l)
Car, year, motor etc?
My guess is your temperature control sensor, the one that plugs basically in right by the t-stat.
Old Nov 28, 2005 | 03:13 AM
Lmgrcivic's Avatar
Default Re: my fan wont turn on, i read threads, have questions (.ken)
check all the fuses first then go from there.
Old Nov 28, 2005 | 04:54 AM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">My guess is your temperature control sensor, the one that plugs basically in right by the t-stat.</TD></TR></TABLE>
That is the most common problem. Coolant temp switch.
Old Nov 28, 2005 | 05:05 AM
Falqon's Avatar
Check the fuses, both underneath the dashboard and in the engine bay. Then jump the relay in the engine bay box that controls your fan and see if that's the problem. Probably something simple like a fuse or the ECT switch screwed into your engine.
Old Nov 28, 2005 | 07:10 AM
egryda's Avatar
Default Re: my fan wont turn on, i read threads, have questions (Falqon)
your thermostat could have taken a ****.
LiL JoN
29
Aug 5, 2009 10:46 AM
aznlaoboi315
Mar 13, 2008 02:35 PM
FONK
Jan 11, 2006 08:48 PM
xsellxoutx
35
Sep 7, 2004 11:42 AM
90Accord-R
Oct 17, 2003 07:30 AM
