What tire pressure?
Old Mar 13, 2002 | 09:25 AM
Double 0 Seven's Avatar
Default What tire pressure?
Falken Azenis
205/50/15
For Street only
New Jersey
Old Mar 13, 2002 | 09:36 AM
yoshi234's Avatar
I shoot brides
Default Re: What tire pressure? (Double 0 Seven)
Not sure what it should be in NJ, but in SoCA I run 34 all around
yshi - who had two nails removed from BOTH rear falkens
Old Mar 13, 2002 | 09:37 AM
davidnyc's Avatar
ask "el pollo diablo", he is in the NY/NJ/CONN area and has the Falken Tires.
Old Mar 13, 2002 | 08:55 PM
nsxtcjr's Avatar
New User
Default Re: What tire pressure? (davidnyc)
As a general rule, start with the factory recommendation (35F/33R) and adjust from there as needed.
Old Mar 13, 2002 | 08:59 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Re: What tire pressure? (nsxtcjr)
39F/37R
Old Mar 13, 2002 | 09:00 PM
Type Goch's Avatar
New User
Default Re: What tire pressure? (01PYTypeR#1140)
39F/37R
for street? those look like auto-x pressures.
[Modified by Type Goch, 10:00 PM 3/13/2002]
Old Mar 13, 2002 | 09:10 PM
Default Re: What tire pressure? (Type Goch)
On stock rims 205/50/15 are a little sloppy for street driving. They almost feel like you're on a boat ride, because the stock rim isn't too wide. 39F/37R solved this problem in my case.
Old Mar 13, 2002 | 09:13 PM
BoM's Avatar
BoM
i run 34psi all around in nj
but on toyo fz4's
Old Mar 14, 2002 | 01:02 AM
SoCal ITR's Avatar
Default Re: What tire pressure? (BoM)
Would 195/55 15 have less play than the 205's?
Old Mar 14, 2002 | 04:52 AM
Default Re: What tire pressure? (SoCal ITR)
Yes! That is factory spec. for stock rim,
rice r0cket
Sep 3, 2003 09:40 AM
EminemGSR
May 22, 2002 11:18 AM
Renegade
Apr 4, 2002 01:05 PM
4doorH22
11
Oct 3, 2001 04:36 PM
rltrock
Aug 29, 2001 02:17 PM
