wtf is a code 67?? help me out
Old Nov 27, 2005 | 06:12 PM
Superdragr45's Avatar
Default wtf is a code 67?? help me out
i was driving yesterday and i had just changed my secondary o2 and my FPR to a B&M FPR. then, i throw a code 67 and i have no idea was that code is........annyone kno wat it is??? someone help me out.....
Old Nov 27, 2005 | 08:24 PM
Default Re: wtf is a code 67?? help me out (Superdragr45)
anyone?
Old Nov 27, 2005 | 08:31 PM
EJ8VTEC's Avatar
Mr. Indecisive
OBD1 OR 2??
Old Nov 27, 2005 | 08:36 PM
komat's Avatar
you sure it isnt two codes
Old Nov 27, 2005 | 08:53 PM
Default Re: wtf is a code 67?? help me out (komat)
it flashed as all one code
its an OBD2 motor........(99 LS)
Old Nov 27, 2005 | 09:01 PM
Luserkid's Avatar
Friend threw that same code. I believe he has the same mess up as you which is that its trying to throw Code 65 and Code 2 which are both for o2 sensor. Why exactly did you change your o2 sensor before hand and did you install it right?
Old Nov 27, 2005 | 09:21 PM
Default Re: wtf is a code 67?? help me out (Luserkid)
yea, just simple plug and play, right??
wat happens is that it throws a code when it gets WOT. doesnt do it until i push it hard.
Old Nov 27, 2005 | 10:12 PM
EJ8VTEC's Avatar
Mr. Indecisive
how did u find out what code it is, with obd2 the jumper trick doesnt work... obd2 codes have more digits, u need a obd3 diagnostic tool
Old Nov 27, 2005 | 10:40 PM
vancoland's Avatar
Ecu code 67(Catalyst System Efficiency Below Threshold)
its a dumb code...i don't know why obd2 have them...your new o2 might be having wrong readings or your cat might be fawked...try and see if theres rattles when you hit the cat
Old Nov 27, 2005 | 10:53 PM
vancoland's Avatar
Default Re: wtf is a code 67?? help me out (EJ8VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC &raquo;</TD></TR><TR><TD CLASS="quote">how did u find out what code it is, with obd2 the jumper trick doesnt work... obd2 codes have more digits, u need a obd3 diagnostic tool</TD></TR></TABLE>
uhh...the jumper trick works fine...obd1 and 2 have the same codes when you jump it...its scanner that have different codes
Old Nov 28, 2005 | 09:46 AM
Default Re: wtf is a code 67?? help me out (vancoland)
i kno why i have that damn code. its because im running a test pipe right now. u think that could be the problem???
Old Nov 28, 2005 | 03:14 PM
vancoland's Avatar
yes...that is your problem...thats why its a dumb code, run a o2 simulator or....i heard some people cut the electrical from the second o2 to the ecu to get rid of the light
Old Nov 28, 2005 | 03:26 PM
EGmikeH22's Avatar
* B A N N E D *
cough : third post from the top : cough
https://honda-tech.com/zerothread?id=1171263
Old Nov 28, 2005 | 04:18 PM
vancoland's Avatar
Default Re: (EGmikeH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmikeH22 &raquo;</TD></TR><TR><TD CLASS="quote">cough : third post from the top : cough
https://honda-tech.com/zerothread?id=1171263</TD></TR></TABLE>
lol...i answered his question already...and jdmlyfestyle doesn't post a code 67 on his list...cough: read :cough
SexyHatchie
Aug 22, 2007 04:44 AM
b18_crx
Oct 27, 2005 05:19 AM
B18C1 '96 Coupe
Jul 2, 2003 08:43 AM
