transmission problem Need HELP!!
Old Nov 27, 2005 | 05:21 PM
kihun_cha's Avatar
Default transmission problem Need HELP!!
Well current motor is ls/vtec wit gsr tranny but it was so fine til today in afternoon when i mis shift second gear like a dumb *** and i grind my gear doing 8k rpm.....=T so stupid and now it's real hard to get into gears and also it would grind 3rd gear and 4thgear real bad.. almost everytime it would grind 3rd gear.. i dont know what it could go wrong? mabye a fluid? but its weird since it happened after i grind very bad.. can it be syncro??
Old Nov 27, 2005 | 05:46 PM
anony95ex's Avatar
Default Re: transmission problem Need HELP!! (kihun_cha)
Sounds like possibly bad synchro(s) and/or bad shift fork(s).
Old Nov 27, 2005 | 05:57 PM
kihun_cha's Avatar
when the motor is off, and i shift, it shift so well and fine.. but when motor is on, its real hard to shift.. basically its real hard to get into gears
Old Nov 27, 2005 | 06:10 PM
kihun_cha's Avatar
bump need help man
Old Nov 27, 2005 | 06:14 PM
anony95ex's Avatar
Default Re: (kihun_cha)
I got your IM on the board, but I'm a trial user and can't respond that way and I'm limited to 5 posts per day for now. Hit me up on AIM if you can...Anony77882
Old Dec 19, 2005 | 02:34 PM
92_EGhatch's Avatar
Default Re: (anony95ex)
you need new clutch forsure... that's what happen to my bro car too, and its the clutch spring that poped out....
98slowvicEX
Aug 28, 2012 06:20 PM
NOOdS
Apr 20, 2009 11:04 AM
boosted_EM1
12
Feb 7, 2008 12:58 PM
ALL IMPORT
Sep 1, 2006 08:01 PM
Ottoman
May 8, 2003 10:01 AM
