Suspension & Brakes Theory, alignment, spring rates....
New upper a-arms are missing ball joint
Old Nov 27, 2005 | 04:07 PM
TurboLaxx's Avatar
Default New upper a-arms are missing ball joint
Well i just purcahsed a pair of ingalls upper a-arms but they are missing the ball joint. Do i just put my original ball joints into these? If so how do i do it? Here's what it looks like:
This is for a 2000 Civic.
Old Nov 28, 2005 | 08:13 PM
TurboLaxx's Avatar
Default Re: New upper a-arms are missing ball joint (TurboLaxx)
bump
Old Nov 28, 2005 | 09:57 PM
Cory Matthews's Avatar
i think you take your original balljoints, press them into the silver plates and then bolt the plate to the a-arm.
Old Nov 28, 2005 | 10:53 PM
Erik95LS's Avatar
Default Re: New upper a-arms are missing ball joint (z6 coupe)
I agree with him, but it may be more worth it to just go ahead and get new ones for these.
Old Nov 29, 2005 | 07:42 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: New upper a-arms are missing ball joint (Erik95LS)
I always thought that the original upper balljoints could not be removed from the UCA. I could be wrong though. You may want to give Ingalls a call & find out if those are supposed to come with new balljoints...
Camber kits suck anyways since they cause interference problems with your shock tower when your lowered. I would just sell them & run stock upper control arms. I do, and I have no tire wear issues (lowered 2.75" for 5 years). A good alignment goes a long way (zero toe baby)...
Old Nov 29, 2005 | 08:04 AM
Erik95LS's Avatar
Default Re: New upper a-arms are missing ball joint (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">I always thought that the original upper balljoints could not be removed from the UCA. I could be wrong though. You may want to give Ingalls a call & find out if those are supposed to come with new balljoints...</TD></TR></TABLE>
You can. Its not hard. I've had to do it a couple times.
Old Nov 29, 2005 | 12:05 PM
ATS*Mark's Avatar
OG triple OG
my last civic i ran a skunk2 camber kit for 3 years and it tore the ******* **** out of my shock towers , made noise and blew balljoints all the time , i then switched to an SPC camber kit which was ok . on my new hatch theres no camber kit and no wear on the tires , i wont run another camber kit.
Old Nov 29, 2005 | 05:15 PM
Default Re: New upper a-arms are missing ball joint (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">my last civic i ran a skunk2 camber kit for 3 years and it tore the ******* **** out of my shock towers , made noise and blew balljoints all the time , i then switched to an SPC camber kit which was ok . on my new hatch theres no camber kit and no wear on the tires , i wont run another camber kit.</TD></TR></TABLE>
man i was blowing balljoints on my stock a-arms too. the ball joint would come out of the a-arm, what i did was take a BFH, put it back in place and welded that bitch.
and btw you dont need aftermarket camber kits, i think its better to find a shop that can fix camber by bending your steering kunckles.
Old Dec 1, 2005 | 04:07 AM
KTeller8's Avatar
i can get you some new replacment ball joints if you need. pm me and ill link you to that item on our site.
scorpion-stinger
Apr 17, 2009 09:59 AM
matryx
Jul 25, 2008 09:14 PM
AllMtorEg
Suspension & Brakes
Mar 31, 2008 08:34 AM
Frosty_spl
Oct 29, 2002 11:05 AM
