jdm d15b vtec questions
Old Nov 27, 2005 | 11:18 AM
bamm_bamm89's Avatar
Default jdm d15b vtec questions
i have some questions about the jdm d15b vtec
about the pistons ive heard that u have to get them specialy made. how much does that cost?
d15bs are hydro trannys but could they bolt up to a cable tranny?
whats the d15b C/R?
whats the best ecu for a d15b?
besides hmotorsonline.com what are some other sites to buy the d15b from?
thanks.
Old Nov 27, 2005 | 11:29 AM
Down Shift Motoring's Avatar
Default Re: jdm d15b vtec questions (bamm_bamm89)
i got my d15b from hmotors... ummm you can try jaydm.com and also passwordjdm.com donno if they have em n e more though. dunno on the pistons never had to change them but i think d series pistons would work fine. i used a p72 ecu gsr.... worked great vtec you heard but didnt pull as hard as my dohc. i used my stock si tranny also and it worked good, just put a new clutch and flywheel on.
Old Nov 27, 2005 | 11:37 AM
k thanks for the info and ive heard that the pistons like 3mm off the regular d-series pistons so if i tryed to use a like a d16z6 or a d15b7 or somthing like that piston it would be higher then the sleaves and will expletive up the motor.... so ive heard
Old Nov 27, 2005 | 07:09 PM
*bump*
Old Nov 27, 2005 | 07:41 PM
Mach69's Avatar
Default Re: jdm d15b vtec questions (ef9typer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9typer &raquo;</TD></TR><TR><TD CLASS="quote">i got my d15b from hmotors... ummm you can try jaydm.com and also passwordjdm.com donno if they have em n e more though. dunno on the pistons never had to change them but i think d series pistons would work fine. i used a p72 ecu gsr.... worked great vtec you heard but didnt pull as hard as my dohc. i used my stock si tranny also and it worked good, just put a new clutch and flywheel on. </TD></TR></TABLE>
You used a dohc b-series ecu for a sohc d series engine? That would make the engine run really rich imo.
I've never heard of having your pistons specially made. ?
Cable Transmission will bolt up.
The ratio is 9.1:1 I believe.
The best ecu for the d15b is either a p28 or p08 (i think thats what comes with it stock).
Old Nov 27, 2005 | 07:44 PM
Default Re: jdm d15b vtec questions (Mach69)
dammit i wrote gsr ecu i used a p28 sorry my bad
Old Nov 27, 2005 | 08:56 PM
Mach69's Avatar
Thats better.
Old Nov 27, 2005 | 09:07 PM
beyondspexj's Avatar
you can use any d series rods
pistons either have to be custom made or you would need to use suzuki vitara pistons
Old Nov 27, 2005 | 09:13 PM
crxforum's Avatar
Default Re: (beyondspecs_jamar)
Does anyone know of a JDM D15B motor's dist and fuel pump are the same as the USDM D15Bs? Also are the spark plug wires? Sorry to jack the thread. Didnt think I would need to make a new one.
CRX Forum
Old Nov 27, 2005 | 09:30 PM
i dont care i might need to know thoes questions too later on anyway
Old Nov 27, 2005 | 09:45 PM
keep your stock fuel pump its fine
dizzy is from a z6 same with the plug wires
Old Nov 27, 2005 | 10:00 PM
FOMULA91's Avatar
I have an OBD0 PR4 ECU from an LS that works Great!!!
Old Nov 27, 2005 | 10:08 PM
i hope you had it chipped for a single cam fuel map or turned the fuel pressure down. if not your running the motor rich and a ls ecu isnt programed to for any vtec motor
Old Nov 28, 2005 | 10:29 AM
.Unknown.'s Avatar
Hey I'm getting my D15B Soon and I want to stay OBD-0. I heard the PR3 is best for that motor anyways? Any Comments?
Old Nov 28, 2005 | 08:51 PM
you are not going to be able to get the performance you should get out of the motor by staying obd0. but use the jdm b16 ecu. warning tho, it will run rich
Old Nov 28, 2005 | 09:15 PM
.Unknown.'s Avatar
QUESTION.... Will the 90 CRX Flywheel / Clutch and Tranny bolt up directly to the D15?
Old Nov 28, 2005 | 09:54 PM
answer..lol jk
yea it will
Old Nov 28, 2005 | 11:36 PM
court's Avatar
25 Year Member
yes, all d series parts are inter changeable with eachother. there are some small eceptions. this includes zc parts as well (except twin cam motors)
Old Nov 29, 2005 | 12:09 AM
.Unknown.'s Avatar
Just Makin Sure... And One last question for me... I know the D15B comes OBD-1.... and my car stock is OBD-0... When placing the motor in all i need in a kit where my Stock ECU connects converted over to a OBD-1 Harness... If you understood that haha?
Old Nov 29, 2005 | 07:27 AM
no you need more then that. you need:
p28 ecu
obd1 fuel injectors and matching pigtails (92-95 civic)
obd0-obd1 harness
4 wire o2 sensor
Old Nov 29, 2005 | 09:09 AM
slywfbpsi's Avatar
The c/r is 9.4:1. Some have used z6 pistons as well as vitrara pistons. Which makes since, because the compression height of the z6 and vitrara pistons are the same. If you are scared to try that then use 01-03 gx pistons, they have the same compression height of the d15b (27mm), or go custom.
Old Nov 29, 2005 | 10:26 AM
.Unknown.'s Avatar
Well I'm Getting the Motor From HMO... Check their Site out... And let me know what i need to make it run.. As far as i was told All i need was a OBD0 to obd1 Harness to run the P28.
Old Nov 29, 2005 | 10:30 AM
court's Avatar
25 Year Member
Default Re: (.Unknown.)
you can also use a pm6( 88-91 si/ mpfi) or pr4( non vtec twin cam/mpfi) ecu, and run a vtec activator switch, like a vtec controller
Old Nov 29, 2005 | 07:11 PM
and using a switch is basicly pointless as vtec relys on more than a eletrical source to the sielnoid (sp? lol)
Dante Civic
12
Dec 13, 2007 04:19 PM
KooK
May 2, 2006 01:30 PM
steinar
Jun 1, 2005 02:10 PM
Blanket Jackson
Sep 29, 2004 04:19 PM
sslude
Jan 30, 2003 06:20 PM
