StopTech Lines
Old Nov 27, 2005 | 10:50 AM
WVTURBOCRX's Avatar
Default StopTech Lines
Application:89' CRX SI with rear brake swap. The Calipers & Trailing arm are from 91 Teg.
I purchased StopTech Stainless Steel Brake Lines. Mfg Part Number: 85-054-5500(R), for the rear only from buybrakes.com; However look at the photo, the end does not fit onto the rear calipers, the metal flange is way to short and shaped wrong
My question... Has anyone else had this problem with these same lines?
Also what lines are you using that went on without a hitch?
[IMG][/IMG]
Old Nov 27, 2005 | 12:02 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: StopTech Lines (WVTURBOCRX)
photo dont work
Old Nov 27, 2005 | 12:05 PM
Autoworks's Avatar
Default Re: StopTech Lines (rukawa1one)
can you enlarge that pic?
Old Nov 27, 2005 | 12:17 PM
EL Vap133's Avatar
What car did you purchase the brake lines for? Did you ask for 89 Si brake lines? Or did you ask for Teg brake lines?
If you asked for 89 Si brakes lines, then you got the wrong ones since 89 (CRX) si's didn't come with rear disc brakes.
Old Nov 27, 2005 | 12:40 PM
WVTURBOCRX's Avatar
Default Re: StopTech Lines (EL Vap133)
Yes, they are for the Integra. I emailed BuyBrakes, still waiting on responce. Click on pic to enlarge.
Old Nov 27, 2005 | 05:09 PM
WVTURBOCRX's Avatar
What other brake lines do you know that works?
Old Nov 27, 2005 | 06:29 PM
Autoworks's Avatar
If you ordered the lines for the 91 Teg, the only thing I could think it could be is that you got the wrong part. Though I never did my rear, I changed my complete front knuckles/calipers/rotors/lines to DA setup and used DA lines up front, it whould be the same in the rear.
gRim06
Oct 28, 2007 02:14 PM
Reelizmpro
Jul 12, 2007 05:05 PM
WVTURBOCRX
Suspension & Brakes
Nov 27, 2005 12:43 PM
chadmasterc
Feb 24, 2004 08:23 PM
sabertooth
Jan 7, 2004 10:09 PM
