Alignment
Old Nov 27, 2005 | 06:34 AM
ED9man's Avatar
Default Alignment
I'm getting my car aligned on Monday since I just install my new Hankook Ventus R-S2's on my stock 14 inch wheels of my 88 CRX Si with stock suspension. What is the best setting to have it put at? Naturally I want the alignment optimized for cornering, but I dont want a setting that will wear the tires excessively. Should I stick to the stock setting which is probably optimized to track straight easily or is there a better setting I can have done optimizing it for cornering without prematurely killing my tires? Thanks.
Old Nov 27, 2005 | 07:14 AM
Autoworks's Avatar
Default Re: Alignment (ED9man)
Stock, if you have stock suspension, all they can do is set the toe for the most part anyway. Just set it to stock, your other specs will probably still be within OE tolerance anyway (+/- 1degree)
chahsiubow
Jul 14, 2007 01:02 AM
Togapiggy
Mar 20, 2007 09:18 AM
ITR Motorsports
10
Feb 2, 2007 08:21 PM
ED9man
Suspension & Brakes
Nov 29, 2005 04:34 PM
Type R 564
Jul 20, 2003 08:42 AM
