JDM wiring harness
Old Nov 27, 2005 | 12:09 AM
DragonDRFTR's Avatar
Default JDM wiring harness
I'm tryin' to swap a JDM B16 into my eg. The only problem I seem to be have right now the fact that the wiring harness is meant for right hand drive. I think I figured out wat to do for the battery/ starter cable, but the only problem I seem to b having is with the fuse box cable which is meant for right hand drive
Old Nov 27, 2005 | 02:40 AM
JDMlyfestyle's Avatar
what i do when i get stuck with a JDM harness. is say expletive the alternator power wire.. and i go to a radio supply store and buy a 2.5-3ft 8 gauge Wire with 2 terminals and install it in its place.
Old Nov 27, 2005 | 08:09 AM
hatchi's Avatar
Default Re: JDM wiring harness (DragonDRFTR)
i would use a usdm wiring harness to save time and figuring out the wiring
Old Nov 27, 2005 | 08:13 AM
Nuke209's Avatar
lol, I'm using the JDM harness in my car, I just stretched one underneath the Intake manifold and the other one, over the intake manifold, fits good...just remove the battery and alternator cable from your old engine, and it'll be fine, I did that
Old Nov 27, 2005 | 08:14 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Nuke209)
Use a USDM harness and modify a few plugs so it fits. MUCH easier.
Old Nov 27, 2005 | 09:48 AM
so u think it would b ok if I cut the jde battery postive???
absolut b18
Jun 22, 2003 11:10 PM
24hourflipness
Apr 26, 2003 10:37 AM
g's integ
May 16, 2002 04:16 PM
