hairline crack on block by oil squirters? has anyone seen this before?
Old Nov 26, 2005 | 10:59 PM
the.hamburglar's Avatar
Default hairline crack on block by oil squirters? has anyone seen this before?
rebuilding the motor and noticed some hairline cracks. i have 4 going through the holes where the oil squirters bolt in. anyone see this before?
Old Nov 26, 2005 | 11:14 PM
rjay8604's Avatar
Default Re: hairline crack on block by oil squirters? has anyone seen this before? (the.hamburglar)
Are you sure its not just casting flash?
Old Nov 27, 2005 | 07:20 AM
rmcdaniels's Avatar
The casting marks do look like cracks, made me wonder when I first saw them.
Old Nov 27, 2005 | 10:23 AM
no im pretty sure its not the casting. ill take pics and post them soon
Old Nov 27, 2005 | 09:04 PM
and whats all this peeling/cracking below?
Old Nov 27, 2005 | 09:41 PM
SkRiBLaH's Avatar
thats all from the casting of the block. you should be good to go.
just to double check, cut a small bit off the top of the "crack". im sure tis just flash or a cosmetic defect.
Old Nov 27, 2005 | 09:47 PM
rjay8604's Avatar
Default Re: hairline crack on block by oil squirters? has anyone seen this before? (SkRiBLaH)
Looks like flash to me too. it is somewhat tricky to tell the difference. The first time you see it its like, holy crap my block is shot! But once you see some cracks vs. flash you will be able to readily tell the difference between the two.
Old Nov 28, 2005 | 09:58 AM
Default Re: hairline crack on block by oil squirters? has anyone seen this before? (rjay8604)
what is flash? it really looks cracked by the squirters.
Old Nov 28, 2005 | 11:25 AM
jdmcoop's Avatar
Take a fine grit sandpaper and sand it flush by moving across (90 degrees to the line). If it disappears, it's just a casting flash. Don't sand in line with it or you'll blend a crack in if it's really a crack. It is common for these blocks have casting marks in that area.
Old Nov 28, 2005 | 02:16 PM
Default Re: hairline crack on block by oil squirters? has anyone seen this before? (sleeper-ek)
ok but what is this flash your all talking about? just another word for small cracks in words of the honda-techers?
Old Nov 28, 2005 | 02:42 PM
bosco500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">ok but what is this flash your all talking about? just another word for small cracks in words of the honda-techers?</TD></TR></TABLE>
Its a casting mark from when the block gets cast. Not a crack.
Old Nov 28, 2005 | 04:18 PM
Default Re: hairline crack on block by oil squirters? has anyone seen this before? (bosco500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bosco500 &raquo;</TD></TR><TR><TD CLASS="quote">
Its a casting mark from when the block gets cast. Not a crack.</TD></TR></TABLE>
ok look closer is obviously not a casting mark. i can run my nail on the crack and it will catch.
Old Nov 28, 2005 | 04:25 PM
mmuller's Avatar
Mad Scientist
those are casting flaws, not cracks
If it would be a crack it would go all the way up to the neck.
Old Nov 28, 2005 | 04:39 PM
Default Re: hairline crack on block by oil squirters? has anyone seen this before? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">those are casting flaws, not cracks
If it would be a crack it would go all the way up to the neck.</TD></TR></TABLE>
true, so i have nothing to worry about?
Old Nov 28, 2005 | 05:07 PM
thehatchninja's Avatar
did you try sanding it like everyone is telling you to?
Old Nov 28, 2005 | 06:02 PM
Default Re: hairline crack on block by oil squirters? has anyone seen this before? (thehatchninja)
no i put my fingernail on there and realized id be sanding for a while
Old Nov 28, 2005 | 06:36 PM
Combustion Contraption's Avatar
Better to be sanding for a while to be sure than rebuilding for a long while because you didnt check.
Old Nov 28, 2005 | 07:25 PM
Nikos's Avatar
Default Re: (LsVtec92Hatch)
i found the same cracks on my tsx block but after I sent it to ERL they told me not to worry about it.. they are from the casting...
I would not suggest you sand it.. bad idea.
Sp00nFed EM1
K Series
Apr 4, 2012 06:39 AM
em1 Ziggy
May 12, 2006 11:08 PM
mo0cow
Oct 26, 2005 04:36 AM
Boostless97Lude
Jan 18, 2003 08:19 PM
