b16 in teg
Old Nov 26, 2005 | 10:13 PM
91teg's Avatar
Default b16 in teg
i just put a b16 in my teg. still running pr4 ecu. swaping out pr4 for pr3 tomorrow. when i am goin down the road the engine doesnt get warm. when it sits at a parking lot it gets warm...? i turn the heater on when i am driving and it is warm for a split second and then it gets cold. any suggestions?
Old Nov 27, 2005 | 12:22 AM
Integra_drk's Avatar
Default Re: b16 in teg (91teg)
im confused. do you mean the engine temp itself, or just the heat and ac?
Old Nov 27, 2005 | 06:54 AM
nitrofish420's Avatar
Sounds like a thermostat stuck open. Try replacing that first, it should take care of it.
Old Nov 27, 2005 | 08:57 AM
v-tec maz's Avatar
Default Re: b16 in teg (nitrofish420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrofish420 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a thermostat stuck open. Try replacing that first, it should take care of it. </TD></TR></TABLE>
Old Nov 27, 2005 | 10:12 AM
91teg's Avatar
the heat/ac... its weird, let it warm up for 5 mins and its warm and toasty, but if you start driving it it isnt warm air coming out of the vents anymore. and the engine idles at 1500 like it isnt warm...? which thermo should i use? will a b18 thermo be alright? thanks
Old Nov 27, 2005 | 10:40 AM
Any B series 'stat should do. Many prefer OEM, but aftermarket should work fine too.
Here's the Honda part number I found in another post... # 19301-P08-315
Old Nov 27, 2005 | 01:27 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91teg &raquo;</TD></TR><TR><TD CLASS="quote">the heat/ac... its weird, let it warm up for 5 mins and its warm and toasty, but if you start driving it it isnt warm air coming out of the vents anymore. and the engine idles at 1500 like it isnt warm...? which thermo should i use? will a b18 thermo be alright? thanks</TD></TR></TABLE>
Yup, definitely sounds like a stuck open thermostat, or a thermostat not even being there at all.
It gets warm when you're sitting there because there's no air flowing through the radiator. The coolant gets warmed by the engine, and flows through your heater core and you get warm air. As soon as you start driving, since the thermostat is open (or not there), the coolant continuously cycles through not giving it time to "heat up" so you don't get hot air from the vents.
Any Honda thermostat is fine, or even just an OEM replacement at Pep Boys or something. That's what I use.
91slamedrex
15
Oct 7, 2006 11:50 AM
89 CRX SI
Apr 20, 2004 10:35 AM
Tomatohatch
Dec 19, 2003 05:08 PM
RS_91
12
Jun 11, 2003 12:47 PM
Blue teg
Jan 23, 2002 09:24 PM
