ITR Header on my B-series Swap?
I have a 1996 Civic hatchback with a B18C1 engine swap. I want this ITR header http://www.jspecautosports.com...d=104
but am wondering about fitment issues. I know that it will bolt up to the engine no prob, but how will it fit against the cat? The cat is just a standard OEM cat (gutted). How can I get it to bolt up? any kits available? adapters?
the header will fit without a problem.
your stock oem cat will not fit due to the 2.5 inch collector.
you'll either need to pruchase a jdm itr car and extend it ( it is shorter in length than usdm cats) if you want to retaine a cat or get a test pipe made, bought or fabbed for your set up.
Hey, one more question if you don't mind. Which pipe should I order? I have a Apexi WS exhaust, a 96 HB with a b18c1 swap. which car do i order the test pipe for? the integra type-r? the 96 HB? and since i am using the JDM ITR header do i order the JDM spec test pipe? here's the chart of applications: http://www.prostreetonline.com...pipe/ help! lol
just go to a muffler shop they will know what to do...unless you can fabricate and by you asking this question i take it you dont...so go to midas 20-30 bucks youll be set.
well i can get "that fake crap" for 75 dollars less and it is identical, so i'll go with the brand new, cheaper (and identical) "fake crap" than your exactly the same and used real one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx »</TD></TR><TR><TD CLASS="quote">My advice would be to get an Omni test pipe since its goign to give a bit better results than a gutted cat and it has length adjustability.</TD></TR></TABLE>
ditto
ditto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_dohc »</TD></TR><TR><TD CLASS="quote">The "fake" one is fine. My buddy(LSVT3K 91 CIVIC) has the real one, and I have the "fake" one. Same damn thing</TD></TR></TABLE>
What about materials and build quality?
