B16a motor is Overheating. What could it be?
My Del Sol is overheating.I have a B16a SiRII motor in it. I checked coolant levels and oil level. There are no coolant leaks anywhere. I did notice that the cooling fan is not working. Could that be the sole problem.Any ideas?
It can be a termistat. Crank up your car let it idle for like 5 min, then squeze ur radiator hose, if the hose is hard, change it out. Its not hard to change a termistat. just take out the termistat housing out the replace it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenedEK »</TD></TR><TR><TD CLASS="quote">It can be a termistat. Crank up your car let it idle for like 5 min, then squeze ur radiator hose, if the hose is hard, change it out. Its not hard to change a termistat. just take out the termistat housing out the replace it.
your close but a little off, let your car warm up and keep feeling the lower radiator hose to see if the thermostat opens. If your car overheats and the lower hose is cold its your thermostat, it its hot then your fan switch(whatever its called) is bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdelsolo »</TD></TR><TR><TD CLASS="quote">I did notice that the cooling fan is not working. </TD></TR></TABLE>
I changed the fan switch and everything seems to be working all right. I am going to drive it harder and see what happens.
It is the thermostat. Still overheating and the upper radiator hose is blazing hot while the lower is cold. Does that sound like a thermostat to you guys?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdelsolo »</TD></TR><TR><TD CLASS="quote">It is the thermostat. Still overheating and the upper radiator hose is blazing hot while the lower is cold. Does that sound like a thermostat to you guys?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatchb18c1 »</TD></TR><TR><TD CLASS="quote">
your close but a little off, let your car warm up and keep feeling the lower radiator hose to see if the thermostat opens. If your car overheats and the lower hose is cold its your thermostat, it its hot then your fan switch(whatever its called) is bad.</TD></TR></TABLE>
hhhhmmmm......
hhhhmmmm......
mite be your thrmostat, jus change it neway, takes like 30 min, u might as well change ur water pump too before it goes, and while your at it your timing belt..this is alot more work.....my thermostat was bad, but instead of overheating, it would under heat and never warm up
ctrek89
May 23, 2008 06:45 PM
BoostedSi
Feb 6, 2003 07:36 PM
