question about 02 civic si hubs
Old Nov 26, 2005 | 08:28 PM
ghettochild's Avatar
Default question about 02 civic si hubs
all im needing to know is for me to go five lug on a 02 civic si can you just swap the 5 lug hubs and the rotors from a 05 civic si can you still use the stock 02 si's
brake calipers
thanks
Old Nov 26, 2005 | 09:59 PM
mrDFWmechanic's Avatar
my friend did this swap on his ep3 you'll need the 5 lug hubs and rotors thats itand yes you can use the stock oem calipers. for the front thou i THINK you might need to get the 05 civic si or some rsx axles.
Old Nov 27, 2005 | 02:33 PM
BarracksSi's Avatar
RSX-S axles came with my RSX-S 5-lug swap, fwiw. I'd think that they're necessary.
Old Nov 29, 2005 | 11:36 PM
Default Re: question about 02 civic si hubs (ghettochild)
bump
Old Nov 30, 2005 | 09:10 AM
97 TYPE-R 312's Avatar
This isn't a TYPE-S swap though. So with that, you should be able to run the same axles. However, there are two different part numbers for the right axle assembly. The left is the same. Something to think about when you do the swap. It may work, it may not work.... I've only done base to TYPE-S/R swaps.
-Victor
Old Dec 5, 2005 | 03:19 PM
bump can i just use 05 ep3 5 lug hubs and rotors and keep my calipers
thats all i need to know
Old Dec 5, 2005 | 03:25 PM
jsek's Avatar
Yup, calipers are the same sizes between 03-04
Old Dec 5, 2005 | 04:17 PM
Default Re: question about 02 civic si hubs (jsek)
cool thanks
sabremike21
Honda Civic (2001 - 2005)
Mar 8, 2019 08:32 AM
R.Kelley
13
Aug 18, 2006 07:54 AM
spontaneous ep3
Nov 4, 2004 07:51 AM
00hatch98r
Mar 31, 2003 03:58 PM
