removing sunroof.....headliner
Old Nov 26, 2005 | 07:59 PM
supracrx's Avatar
Default removing sunroof.....headliner
after removing the headliner and removing the 10 bolts holding the track and stuff does it just drop out or whjat? is tehre something that i'm missing...doesn't seem like it wants to come out....
Old Nov 27, 2005 | 02:16 AM
supracrx's Avatar
come on guys....i searched but no one knows?
Old Nov 27, 2005 | 07:26 AM
gtturborex's Avatar
Default Re: (supracrx)
its been a while since i did this but i remember just removing the wiring and when i removed all the bolts it sort of just dropped out. i cant remember off the top of my head if there was anything else but if you still dont have an answer when i get off work ill go take a look at mine and see
Old Nov 27, 2005 | 07:43 AM
erubio14's Avatar
Default Re: (gtturborex)
I wish i had a sunroof
Old Nov 27, 2005 | 07:57 AM
91_CRX's Avatar
Default Re: (erubio14)
You'll find everything you need here:
http://mirror.rivendel.nu/crxc...f.pdf
Old Nov 27, 2005 | 10:55 AM
supracrx's Avatar
Default Re: (91_CRX)
thanks i did everything in that order and i still can't get it out...i left the headliner hanging since for some f$!) reason the rear view mirro won't come off....i can't pop that plastic cover off...i'm try pryint it, pliers nothing....that thing pops right off ?
Old Dec 7, 2005 | 10:39 AM
CDtegGo's Avatar
Thanks for the great info! Much appreciated
Old Dec 7, 2005 | 02:03 PM
Wes V's Avatar
Default Re: (CDteggy)
Now don't get snooty about how long it takes to get a response.
This is what I've got to say based on removing my hatchback's sunroof.
The "cover" over the mounting screws for the mirror just snaps off. However it normally breaks the tabs due to being old brittle plastic.
Once the headliner is fully removed, you should be able to see all the bolts that hold the sunroof assembly in place. At the front, there is a pair of "flanges" that the assembly hangs on while installing the unit.
There are also the drain hoses at all four corners (at least on my hatch). You will have to remove them in order for it to all come free. (I just cut them due to replacing the whole roof section with a non-sunroof panel)
Wes
Old Dec 7, 2005 | 04:01 PM
migizzel's Avatar
Default Re: (Wes V)
im about to replace my sunroof glass and im planing on doing a write uo on is this weekend ill let you know
Old Dec 8, 2005 | 03:56 AM
Shirk's Avatar
Default Re: (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote"> At the front, there is a pair of "flanges" that the assembly hangs on while installing the unit.
I believe those are in the rear
You should consider a helping hand when putting in back up again. Yes, it hurts getting the entire thing falling right on top of your head. Trying to hold up the front and rear while working the bolts all by yourself can do that to you
Old Dec 8, 2005 | 09:03 AM
supracrx's Avatar
yeap i got mine done....it was the rear hangers that were ******* me up hahaha i ddint' notice em i was in rush. i got another sunroof and have it installed.
as for repairing the sunroof...the one i replaced..the right side track would not go up and down completely..i mean it slides perfectly..but just won't shut completely and it opens fine but u can see the track not lifting..i think its a clip or something...i'm trying to fix so i can sell it to a friend...not sure how to repair tho...i just gotta start taking bolts off and see how to repair it..
RangerRingor
Feb 12, 2013 03:55 PM
Rustynuts
Aug 1, 2007 05:44 PM
iphatcrxi
Aug 29, 2006 05:30 PM
transpar_nt
Aug 11, 2005 01:17 PM
LD_EGSICK
Feb 14, 2003 12:05 PM
