1 WIRE TO A 4 WIRE O2?
HAS ANY1 DONE THIS BEFORE?
I HAVE A CX WITH THE 1 WIRE O2.(GOING BAD)
CAN YOU CONVERT THAT 2 A 4 WIRE?
I CAN FIND THE 4 WIRE O2 FOR $50 EVERYWHERE BUT THE
1 WIRE IS LIKE $175
THE 4 WIRE IS BETTER THEN THE 1 WIRE ANYWAY?????????????????
ANY HELP WOULD BE GOOD
1 WIRE IS LIKE $175
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">No reason to if your computer is looking for 1 wire. </TD></TR></TABLE>
true dat. the single wire should be cheaper anyway.
loose the caps also man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DISROK1 »</TD></TR><TR><TD CLASS="quote">
the dx has the same ecu as the cx right?</TD></TR></TABLE>
negative.
the dx looks for a 4 wire o2.
P05 : 92-95 OBD-1 Civic CX
P06 : 92-95 OBD-1 Civic DX
negative.
but if you want to switch, here is a good write up that works, i have used it.
http://www.hybridautomotive.com/tech/o2/#seven
civicracer1993
12
Dec 24, 2003 06:11 AM
