Please Help Quick!! Sensor Question on 2000 EX
Old Nov 26, 2005 | 06:58 PM
HondaGSX's Avatar
Default Please Help Quick!! Sensor Question on 2000 EX
Car: 2000 Civic EX (auto)
I bought a civic with a blown motor and took it out today. Tomorrow I plan to put the new motor in, but when I took the old one out, I noticed I broke a sensor. The new engine does not come with the sensor, and I have no clue what sensor it is. (I think its a sensor).
It is located right under the intake manifold in the back, and I think it is light blue. It plugs directly into the block? I can't find any photo's to show what/where it is and I know it sounds vague as hell. (It is in the rear of the engine and hard as hell to see, even with the engine out of the car. Thank you if you can help - it is very important.
Old Nov 26, 2005 | 07:09 PM
urnotfast's Avatar
Default Re: Please Help Quick!! Sensor Question on 2000 EX (HondaGSX)
pics would help. maybe its a knock sensor. is the new motor same year or is it older?
peace
eric
Old Nov 26, 2005 | 07:18 PM
HondaGSX's Avatar
Default Re: Please Help Quick!! Sensor Question on 2000 EX (urnotfast)
Yeah its the same year as the car, both are d16y8 motors from 2000. I think the sensor may have already be broken, because the clip (which is blue) is broke and the sensor is still in the motor. Its a single wire sensor, so I don't think its too important but it would be great 2 know if I do have a problem. The car is at a friends shop so I can't take a photo (which sux cuz it would help), and I wont get to it til 2m.
Old Nov 26, 2005 | 09:19 PM
green-'s Avatar
Sounds like it is the knock sensor. It plugs into the block just above the oil filter. You will want to fix that, because if it is broken the ecu will pull timing and you will lose power.
Old Nov 27, 2005 | 08:10 AM
hatchi's Avatar
Default Re: Please Help Quick!! Sensor Question on 2000 EX (green00EX)
yes its knock sensor.
Old Nov 29, 2005 | 03:58 PM
HondaGSX's Avatar
Default Re: Please Help Quick!! Sensor Question on 2000 EX (hatchi)
I pulled the old one out of the engine and re-glued it to the wiring harness and then plugged it all back in. If it doesn't connect right, will it send a check engine light? How will I know if it lost power (I bought it w/o the engine).
Thanx
pissybits
Jan 20, 2009 07:35 PM
03dc5Ray
Jul 9, 2008 07:28 PM
juanintec
10
Apr 2, 2008 01:14 PM
Maui Built
Feb 17, 2008 07:22 AM
