Suspension & Brakes Theory, alignment, spring rates....
Alignment
Old Nov 26, 2005 | 06:11 PM
ED9man's Avatar
Default Alignment
I'm getting my car aligned on Monday since I just install my new Hankook Ventus R-S2's on my stock 14 inch wheels of my 88 CRX Si with stock suspension. What is the best setting to have it put at? Naturally I want the alignment optimized for cornering, but I dont want a setting that will wear the tires excessively. Should I stick to the stock setting which is probably optimized to track straight easily or is there a better setting I can have done optimizing it for cornering without prematurely killing my tires? Thanks.
Old Nov 26, 2005 | 10:07 PM
InvaderTrax's Avatar
Stock setting is probably best. Especially on a 14" rim. You really wouldn't notice any better cornering from a slight camber change. Only in tire wear
Old Nov 27, 2005 | 06:32 AM
ED9man's Avatar
Well only toe is adjustable.
Does anyone knowledgable have any ideas?
Old Nov 27, 2005 | 09:18 AM
Solracer's Avatar
Default Re: (ED9man)
Are you autocrossing or doing track events?
If you are have them set the front to to 1/8 total out and 0 in the rear. If you are not auto-x or doing track events, set it to stock specs.
Old Nov 29, 2005 | 04:34 PM
ED9man's Avatar
Default Re: (Solracer)
I'm going to autocross in the spring but mostly street driving, how does your setting behave compared to stock?
Ahknodd
17
May 9, 2008 01:02 PM
ED9man
Nov 27, 2005 07:14 AM
CTR-GSR
Suspension & Brakes
Sep 10, 2005 11:38 AM
MtnCRX
Suspension & Brakes
Mar 26, 2005 03:30 AM
rex_boy
Mar 20, 2002 05:45 AM
