New Cat Offering
Guys I hope I'm not jumping the gun here. I'll be offering a new style Car Sound cat in a few days a long as there are no fitment issues. 2 of these cats have gone out to customers for test fitting and as soon as they install them we'll know if there is improved clearance for the 2nd O2 sensor.
The new cat has the O2 bung in a near stock location. In addition this cat will have an extra O2 bung located before the catalyst. This bung will come with a plug and can be used for a wide band hook up point at the dyno. This is something else that will be checked in the coming days.
I'm also going to be offering an alternative to the 54006, the new cat will look similar to the above but will be shorter for tight installs, i.e. 99 and pre GSRs with JDM headers. This new shorter cat "should" flow better than the 54006 due to increased catalyst area. I plan on having some of these models flow tested in the near future.
Also for those who want to tone the exhaust down a little more, Car Sound is offering a cat with an integrated resonator. However this cat has a longer body and would require modification to the B pipe. I don't think this is a big deal since the majority of the B pipes on systems out there should be modified to match the ID of the cat outlet.
[Modified by SMSP, 6:40 AM 3/13/2002]
I wish you had this a few weeks ago. I had a problems with the O2 clearance on two different Cats. I was finally able to modify one to just clear the shift linkage. Looks like the new one will be much better.
This will work with stock or with JDM 4-1?
I hope you don't forget to let us know when they are available? Is there an estimate price for the JDM headers? Can I get on the list to get one when they are avaiable? Are they going to make the car soudn louder or the same?
Why is the sky blue?
I like to ask questions.....
The sky is blue because people run cats, sorry Mike just had to get that in there.
[Modified by SMSP, 11:05 AM 3/13/2002]
Sorry, I meant the price of the cat for a JDM header.
Check with Dave to make sure. Ed
Will you have a cat like this for a 2000 civic Si??
Yes, you'd need a 2-1/4" for stock set up or the 2-1/2" for JDM. THe cat lengths are the same for the Si and ITRs.
[Modified by 00B16A2 Si, 10:54 PM 3/13/2002]
Does anyone else have a rattle in there carsound?I cant seem to figure out why
my cat makes rattling and buzzy sound(not exaust leak either..Its 1 day old...
the noise happens only while driving and can be heard while driving and then letting off the gas.
[Modified by UNVMYR, 1:23 AM 3/14/2002]
