JDM FRONT HEADLIGHTS (NOOB QUESTION)
Hey I just got my JDM front baught it parted and don't have the bulbs yet, i was wondering what kind of bulbs would i need for them, i've heard you need several since they have yellow/blue/white colored lights. thanks
since you're new.....
using the search feature helps out a lot. It would help to try making that a habit before posting.....so as to avoid the usual banter of flaming if you don't
anyway...I helped you out...
https://honda-tech.com/zerothread?id=1127894
its on the 2nd post.
Well, the bulbs are similar between the HID vs Non HID lights.
Fog - H3
High - H1
City Light - 194
Low - 9006 (non hid uses stock bulb) or D2S (projector-type hid bulb)
Turn -1156a (I believe thats the #, its the amber single filament bulb).
Easy way to tell the hid vs non-hid from t he front, look at the low-beam projector. If it has lines going thru it (on the outer plastic lenses) then its
non-hid (pre 98). if there's a circle in the lense w/ no lines then its a HID front-end (98+).
oh, when u search - click archived and don't necessarily be too specific.
-l8r
Fog - H3
High - H1
City Light - 194
-l8r
so if im correct in understanding you ether way.. i can just use my stock lights from the usdm front and put it on the jdm front as the low 9006 bulbs?
yes. but the same will not apply for your jdm corners. Most will say use an 1156 single filament bulb since the jdm headlight comes with a socket that will work with it. But....you can always get a socket that works with 1157 dual filament bulbs instead so you can have your corners on constantly when you turn your lights on.....and also have them blink too....
