Are integra and civic 's hb rear trailing arms the same?
this has been said a great many times
94-01 integras, 88-00 civics all have the same trailing arm (yes ITR and CTR too).
the 90-93 integras used the same but the bushings were not the same.
It's best to answer this question by how they differ. While the trailing arms might be the same or similar dimension, be mindful of the spindle that's attached to it. For 4 months, I've been hunting the OEM PN for spindles with no success. Some are equipped for drum brakes (most 88-00 Civics), some for disc brakes, and some for ABS (drum or disc). 88-91 Civic/CRXs used a different diameter spindle/bearing than others. Most rear disc ABS spindles have a sensor attached to the lower lobe of the caliper mounting points.
Bolt-On/Swap-ability:
https://honda-tech.com/zerothread?id=1024818
Rear Spindle/Hub info:
https://honda-tech.com/zerothread?id=1349450
TA Identification:
https://honda-tech.com/zerothread?id=1409056
What, exactly, are you swapping biela? Which year/trim/otpions (ABS) for your Hatch? Any previous relevant mods in place?
JasonGhostz
TA Identification:
JasonGhostz
asianflava
Dec 8, 2008 11:14 AM
GserpleaSR
Aug 30, 2006 06:11 PM
func-tion
13
Feb 9, 2004 10:24 PM
