leaking rad fluid
Old Nov 26, 2005 | 03:45 PM
mike9571's Avatar
Default leaking rad fluid
lately ive smelled rad fluid burnin so i checked and its leaking a little bit out the top of the rad.....where the radiator has the little clips bent over....anyone know what to do to fix this?
Old Nov 26, 2005 | 04:22 PM
sooo_slow's Avatar
New User
Default Re: leaking rad fluid (mike9571)
Your best bet, to be on the safe side and just get a new rad. However there is products that are designed for fixing rad leaks, I believe they're almost like and epoxy/fiber glass compound....(I'm not a 100% sure.) which can be found at auto parts stores...
I guess it depends on the severity of the leak....post up some pictures if you can
Old Nov 26, 2005 | 04:28 PM
mike9571's Avatar
Default Re: leaking rad fluid (sooo_slow)
im pretty sure i wont be able to patch it up. after just looking at it its almost all the way across the top...time for a new rad
Old Nov 26, 2005 | 04:30 PM
sooo_slow's Avatar
New User
Yeah, if its big, or you're worried about a patch job, just get a new rad...peace of mind.
whiskywaterwine
Jun 9, 2017 12:36 PM
creator1322
10
Sep 21, 2008 08:13 AM
touandcim
19
Mar 11, 2008 10:10 AM
Knight1
Mar 21, 2006 12:24 AM
TJ R
Jan 20, 2003 09:44 PM
