idle problem
Old Nov 26, 2005 | 02:42 PM
gnar kill's Avatar
Default idle problem
just swapped in my first motor I have ever built, z6 with a y8 intake mani- and b18a throttle body.......the thing idled at like 4000 rpm. soI tried to turn the idle down with the idle screw and got it down to like 3600. I figured something had to be wrong and the only thing I could think of was the bashbot opening up the throttle body so I disconected the vaccuum line that goes to the bashbot and now it idles fine except it dies when it is cold. I think I am gonna just run the thing without the stupid bashpot. Was there a possibility that the bashpot was bad?
I am pretty sure I had everything hooked up right. I had all my vacuum lines just like that one link to the y8 swap on http://www.geocitys/joeyp... something like that sorry I don't got the link...any help would be awesome guys thanx
Old Nov 26, 2005 | 03:02 PM
zccr-xsi's Avatar
try cleaning the evac.that dashpot thing i dont run on my t/b ethier.
Old Nov 27, 2005 | 09:13 PM
gnar kill's Avatar
Default Re: idle problem (gnar kill)
now that I don't got the dashpot in...it likes to die like when I let off the throttle when I am downshiftin between shifts at lower rpms......any suggestions
Old Dec 5, 2005 | 07:29 AM
turbo_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">now that I don't got the dashpot in...it likes to die like when I let off the throttle when I am downshiftin between shifts at lower rpms......any suggestions</TD></TR></TABLE>
yea on the tb there is that lil screw on the bottom of the throttle cable wheel... adjust that down a lil bit and see if that helps it
Old Dec 5, 2005 | 09:08 AM
gnar kill's Avatar
Default Re: idle problem (turbo_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">
yea on the tb there is that lil screw on the bottom of the throttle cable wheel... adjust that down a lil bit and see if that helps it</TD></TR></TABLE>
I did....I tried to get that but it was definetely the bashpot that was makin go to 3000.....but I think I got that little screw where I want it but I dunno.....I think the problem might actually be in my dizzy...I throw a code 9 but it never has had problems until recently....long story on this damn code 9.....
Old Dec 5, 2005 | 02:19 PM
turbo_ef9's Avatar
well i was reading your other post about the dizzy.. are you sure you wired it right since you are running the jk harness? im running the same and i had that problem for a day because i had 2 wires switched around.. double check wiring to the obd1 distrib plugs
Leviatard
18
Oct 30, 2014 09:28 AM
rollinhonda3
Nov 13, 2010 09:53 AM
DaZman69
Nov 12, 2006 07:54 AM
egizzle8
10
Feb 9, 2004 04:25 AM
EGbeater
15
Nov 28, 2003 02:03 PM
