WANT TO FIX SINCROS ON MY JDM TRANNYS ANS YES I SEARCHED ALREADY
Old Nov 26, 2005 | 12:20 PM
88cerx's Avatar
Default WANT TO FIX SINCROS ON MY JDM TRANNYS ANS YES I SEARCHED ALREADY
LIKE IT SAYS I WANT TO KNOW WHERE I CAN GET NEW SINCROS FOR MY JDM TRANNYS. I HAVE A SI AND YS1 FIRST GEN CABLE TRANNYS AND I CANT SEEM TO FIND AND INFO ON PARTS. THERE HAD TO BE SOMEONE THAT HAD DONE THIS SOME TIME IN THERE LIFE.... I HEADR OF A GUY THAT WAS SELLING KITS (DOHC something)
ANY GOOD INFO WOULD BE AWESOME. PLEASE DONT TELL ME TO BUY A NOTHER USED TRANNY I SAW ALOT OF THOSE ANSWERS AFTER SEARCHING
Old Nov 26, 2005 | 12:34 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: WANT TO FIX SINCROS ON MY JDM TRANNYS ANS YES I SEARCHED ALREADY (88cerx)
Try searching "Syncros".. and turning off your caps lock..
http://www.gear-speed.com/
Old Nov 26, 2005 | 12:49 PM
88cerx's Avatar
Default Re: WANT TO FIX SINCROS ON MY JDM TRANNYS ANS YES I SEARCHED ALREADY (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">Try searching "Syncros".. and turning off your caps lock..
http://www.gear-speed.com/</TD></TR></TABLE>
TO EXPENSIVE
Old Nov 26, 2005 | 01:08 PM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88cerx &raquo;</TD></TR><TR><TD CLASS="quote">
TO EXPENSIVE </TD></TR></TABLE>
then just buy a use tranny
becuase they are pretty cheap for oem ones
Old Nov 26, 2005 | 01:17 PM
bagpipe goatee's Avatar
it's really easy to do, but it's not so easy to find them. i'm telling you info you already know, because i want to know too.
also, caps lock is kinda annoying.
Old Nov 26, 2005 | 01:34 PM
88 rex's Avatar
Gear-speed sellls just the synchros. Either in a set of 1-5 or 3/4/5.
I think its like $140 for 3/4/5 which are carbon coated and it depends on which 2ng gear syncro you need will vary the price of the 1-5 set (1 and 2 not carbon coated). At most $265 shipped. You can't buy just the synchro from the dealer, you have to buy the gear set which is $$$.
Good luck. I'll be doing this same thing sometime this winter but hopefully a little more than synchros
88cerx's Avatar
Default Re: (bagpipe goatee)
my bad on the caps im sure if you look at all of my posts about 3/4 of them are caps. bet how much are the parts that i need they dont have prices but was read in other posts they are expensive i should get the barrings and sincros right??????
Old Nov 26, 2005 | 01:36 PM
88cerx's Avatar
Default Re: WANT TO FIX SINCROS ON MY JDM TRANNYS ANS YES I SEARCHED ALREADY (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">Gear-speed sellls just the synchros. Either in a set of 1-5 or 3/4/5.
Good luck. I'll be doing this same thing sometime this winter but hopefully a little more than synchros </TD></TR></TABLE>
wow you posted right befor i did.... lol do i need the gear set cuz it only started to grind 3 days ago
Old Nov 26, 2005 | 03:50 PM
Mach69's Avatar
wow you posted right befor i did.... lol do i need the gear set cuz it only started to grind 3 days ago </TD></TR></TABLE>
Before you go and start spending a lot of money replacing synchros, gears and what not. Why not try and replace your transmission fluid for some good Honda MTF. And wait about a week or two and see if the grinding goes away. If it does, great, I just saved you like 200 bux.
If not, oh well, you were going to replace the synchros/gears anyway.
Old Nov 26, 2005 | 08:17 PM
88cerx's Avatar
Default Re: WANT TO FIX SINCROS ON MY JDM TRANNYS ANS YES I SEARCHED ALREADY (Mach69)
well im doing that to my ys1 that is in there now and i really really want to learn and DO the sincros swap in the s1 that is chillin in my basement
Old Nov 27, 2005 | 01:41 PM
jimi's Avatar
I have aJDM B16B w an S80 trans. I just had my syncros changed. My trans guy just got them from Honda.
Old Nov 27, 2005 | 03:43 PM
88 rex's Avatar
You shouldn't need the gear set, just the synchros. Also, I would take mach69's advice first . If you have tranny just lying around and you plan on rebuilding it, then just take it apart and see what parts are worn/broke and start figuring out what you need from there. Once you start replacing bearings it starts to get expensive b/c alll those bearings add up. Gear-speed sells a "bearing/seal" rebuild kit for about $240. I don't know which bearings it includes though, but I'm sure its all the main ones. I have NEVER bought anything from gear-speed so I am only using their name b/c they are clearly the dominate tranny builder for hondas. They are even contracted with Honda to rebuild their trannies. They know what they are doing and have decent prices for parts......the price for their labor is ....but I guess you get what you pay for.
Old Nov 27, 2005 | 06:42 PM
crxvtecred's Avatar
I bought all new 1,2,3, and 4th gear with syncros from Honda for my YS-1 and it was well worth the 600 dollars.
Old Nov 27, 2005 | 10:28 PM
88cerx's Avatar
Default Re: WANT TO FIX SINCROS ON MY JDM TRANNYS ANS YES I SEARCHED ALREADY (crxvtecred)
thanks 4 the info guys ill call on monday and let u know what they say
Old Nov 27, 2005 | 11:29 PM
Redline130's Avatar
Gear-Speed is a top-notch company. I have a set of carbon-coated synchros in my S1 tranny...very smooth shifting even at 8500+ rpm.
Old Nov 28, 2005 | 11:22 AM
88cerx's Avatar
Default Re: WANT TO FIX SINCROS ON MY JDM TRANNYS ANS YES I SEARCHED ALREADY (Redline130)
ok so i called the guys at gear speed today the prices are sincros=225 for normal1-2 and carbon coated 3-5 and 225 for the berring set and an aditional 20$ each diff berring
not to bad i guess but all im getting is the sincros mabe ill do a sweet write up on how to install them in my s1 cable trans tell me what you think
Old Nov 28, 2005 | 02:33 PM
JG90CRX-Si's Avatar
I too bought all the synchros/bearings from Gear Speed and they were great to deal with. My synchros are still breaking in (stiff shifting) but it was a good investment.
You won't regret it.
JG
Old Nov 29, 2005 | 10:39 AM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88cerx &raquo;</TD></TR><TR><TD CLASS="quote">mabe ill do a sweet write up on how to install them in my s1 cable trans tell me what you think</TD></TR></TABLE>
Good. Maybe then you'll learn how to spell synchro too
illi Adik
Mar 13, 2008 09:46 PM
wHiTeGhOsTdC5
Mar 8, 2008 07:34 AM
Honduh Chicken
11
Apr 25, 2006 03:25 PM
Mag00n
Aug 1, 2005 06:20 PM
prelude1897
May 27, 2003 03:56 PM
