how to take off a flywheel?
Old Nov 26, 2005 | 06:27 AM
aznej2's Avatar
Default how to take off a flywheel?
Hey guys got another question. I have a pulled motor in my garage and need the flywheel off of it... how do u get it off because when i try lossening the bolts the flywheel just spins. Thanks.
Old Nov 26, 2005 | 06:54 AM
aznej2's Avatar
Default Re: how to take off a flywheel? (eg_6_racer)
nvm got it.... for any1 else wandering this... i used the flat end of a crow bar to hold it still.
Old Nov 26, 2005 | 06:56 AM
blkhatch92's Avatar
impact wrench <3
Old Nov 26, 2005 | 07:40 AM
turbofunvtec's Avatar
Default Re: (blkhatch92)
my solution
compressor is 1 of the best tools to own
Old Nov 26, 2005 | 08:32 AM
kyden's Avatar
they actually make a tool that holds the flywheel in place..
Old Nov 26, 2005 | 08:49 AM
blkhatch92's Avatar
screw holding the fly wheel to take it off, just use a compressor and impact wrench, i sex it everynight. lol i love it . . .. . . but, what is this tool called though? ide rather just use a screw driver.
Old Nov 26, 2005 | 10:04 AM
nocturnaldragon's Avatar
I forget what its called but it has teeth on one end that go into the flywheel like a gear, and then you bolt it to the block so it cant turn. Its a nice tool to have if you do that kind of work everyday but I have a compressor and that works fine for me the Few times I need to take it off.
Just remember to torque those bolts back down properly or youll have to pull it all apart again later
Old Nov 26, 2005 | 11:51 AM
civic_driver's Avatar
impact wrench taking it out and prybar between the flywheel teeth when torquing back on
glad you figured it out!
mattbatson
11
Nov 25, 2013 02:52 AM
.Thomas
Jan 16, 2007 10:45 PM
DasaEJ1
Jan 26, 2005 04:37 PM
BlueShadow
14
Jul 31, 2004 04:45 AM
Dr Pooface
Jan 31, 2002 06:07 AM
