itr catback on eg.
Old Nov 25, 2005 | 09:52 PM
bobby frm 3star's Avatar
Default itr catback on eg.
does anyone run it.? i know theres gotta be somebody on HT that have it. well i have a itr catback lying around was wondering if i can use it on my eg.. and would it bolt up without any mod? anybody got pics of it? thanks
Old Nov 25, 2005 | 11:48 PM
CALIdelsolSIR's Avatar
Default Re: itr catback on eg. (newbieS2K)
i believe you might have to trim the exhaust tip just because it will stick out about 4-5 inches away from car, but other then that, it should.
Old Nov 26, 2005 | 07:55 AM
fcukmonsanti's Avatar
The b-pipe will bolt up without any problems but if you are running a rear swaybars the itr muffler will not work, the itr muffler will need to be modified for sure
Old Nov 26, 2005 | 08:08 AM
cxSHOE's Avatar
Default Re: itr catback on eg. (ek4tR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4tR &raquo;</TD></TR><TR><TD CLASS="quote">The b-pipe will bolt up without any problems but if you are running a rear swaybars the itr muffler will not work, the itr muffler will need to be modified for sure</TD></TR></TABLE>
well it doesnt just bolt up...
first you need to measure your civic cat. first off... there will be only two sizes of cats... 15.5 or 17" long. if your civic cat is 15.5" long the type r b pipe will not fit and will be short&gt;&gt; hence you will need to add some piping to the cat or bpipe to make it fit.
if your civic cat is 17" long then the type r b pipe will fit fine without any major modification. gsr cats are smaller. if you want to make it fit with stock parts you will need a 17" long cat (obd2 ls or itr cat). and also you will need to cut and turn the cat. flange since civic and integra bolt locations are different.
and the above posts of the muffler are correct.
i currently run a z6 exhaust manifold to a type r cat with a type r b pipe to a spoon n1 muffler.. no cutting (except the cat flange) and everything fits perfectly fine.
Old Nov 28, 2005 | 08:12 PM
Default Re: itr catback on eg. (cxSHOE)
how is your set up? so it should bolt up perfectly with a 17" long cat?
BoostFrenzy.com
May 15, 2006 01:47 PM
CHiNkStEr
Mar 1, 2005 12:12 PM
cosmic
Apr 9, 2003 12:30 PM
EG Hatch
Feb 18, 2003 07:58 AM
Canttx
26
Oct 31, 2001 07:01 AM
