is this a good set-up weekend/DD
Old Nov 25, 2005 | 08:47 PM
Civic138's Avatar
Default is this a good set-up weekend/DD
i posted this in all-motor and go no response.
does this set-up sound safe enough for a weekend daily driver?
B18A1
Arias Pistons: 10.5:1, 84.5mm
eagle H-beam rods
darton MID sleeves
and ACL bearings
also would would be the Pros & Cons for this set-up?
Old Nov 25, 2005 | 08:57 PM
Pee Wee's Avatar
Default Re: is this a good set-up weekend/DD (Civic138)
any reason why you would need rods and sleeves? is that all your doing to the motor because if so i would think its not needed. all the stuff you have listed is just peace of mind stuff.
Old Nov 26, 2005 | 05:24 AM
Civic138's Avatar
Default Re: is this a good set-up weekend/DD (EF8opey)
the reason for the sleeves is for how thin the cyc walls are, and how much i'll have to bore it for the pistons.
as for the rods, there forged and well, we all know forged parts are stronger then oem
Old Nov 26, 2005 | 05:52 AM
CBURKE's Avatar
I don't see a problem. Like he said, it's just "peace of mind stuff". I would do some head work. Then a little tuning. You should be fine to drive it daily.
Old Nov 26, 2005 | 06:51 AM
CRXBart's Avatar
Default Re: (CBURKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">I don't see a problem. Like he said, it's just "peace of mind stuff". I would do some head work. Then a little tuning. You should be fine to drive it daily. </TD></TR></TABLE>
That and if you are building a All-motor car. I would go 12:1 Compression.
Old Nov 26, 2005 | 08:40 AM
michael O's Avatar
Default Re: (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">
That and if you are building a All-motor car. I would go 12:1 Compression. </TD></TR></TABLE>
That would depend on the quality of gas and tuning.
Old Nov 26, 2005 | 11:35 AM
Civic138's Avatar
Default Re: (michaelOlson)
i have the head,tuning,fuel,air,bolt-on's ect,ect all thought out. i'm just wondering about the bottom end
Old Nov 26, 2005 | 01:15 PM
CRXBart's Avatar
Default Re: (Civic138)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic138 &raquo;</TD></TR><TR><TD CLASS="quote">i have the head,tuning,fuel,air,bolt-on's ect,ect all thought out. i'm just wondering about the bottom end</TD></TR></TABLE>
than crank that compression up, i reed nothing about a vtec head? you keeping it NOTEC?
Old Nov 26, 2005 | 01:26 PM
drdisco69's Avatar
Yeah, as long as you're sleeving it, why not go with a bigger bore and more compression? Seems like a waste to put in sleeves with stock-ish compression and bore. Hell, 0.5mm over is a standard oversize sold by Honda. Think big, man!
Old Nov 26, 2005 | 01:30 PM
88 rex's Avatar
Default Re: is this a good set-up weekend/DD (drdisco69)
ls/vtec i hope.
Old Nov 26, 2005 | 01:43 PM
e jay one's Avatar
Default Re: is this a good set-up weekend/DD (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, as long as you're sleeving it, why not go with a bigger bore and more compression? Seems like a waste to put in sleeves with stock-ish compression and bore. Hell, 0.5mm over is a standard oversize sold by Honda. Think big, man! </TD></TR></TABLE>
he is thinking big he said 84.5 mm bore thats .5 over a b20 bore wich would definatly need sleeves for dd especially on a ls block. and with all that money your gonna put in it i would hope your going vtec.
Old Nov 26, 2005 | 01:47 PM
drdisco69's Avatar
Default Re: is this a good set-up weekend/DD (e jay one)
But while you're sleeving, why not go 85, 86 or even 87? Pistons shouldn't be that much more, if at all.
Old Nov 26, 2005 | 03:37 PM
e jay one's Avatar
i thought the bigest you could go on a b series was 84.5? the walls on a b20 are pretty thin as it is.
Old Nov 26, 2005 | 03:48 PM
Professor15's Avatar
honestly your bottom end depends on your goals, if your just planning on a nice dd/weekend set-up. Then just go with an oem 1.8L block set-up.
Old Nov 26, 2005 | 04:22 PM
Civic138's Avatar
yea,i'm keeping non-vtec, i'm not wanting to build a ls/vtec just yet
Old Nov 26, 2005 | 05:12 PM
si0385.'s Avatar
Default Re: (drchulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drchulo &raquo;</TD></TR><TR><TD CLASS="quote">honestly your bottom end depends on your goals, if your just planning on a nice dd/weekend set-up. Then just go with an oem 1.8L block set-up.</TD></TR></TABLE>
sounds to me like your wasting alot of money on internals for a n/a notec...
Old Nov 26, 2005 | 06:04 PM
Civic138's Avatar
Default Re: (jaydeum4lyfe)
i could always go ls/vtec down the road
Old Nov 26, 2005 | 08:10 PM
theemaddhatterr's Avatar
heres my question for you how muck power are you looking for?
Old Nov 27, 2005 | 05:52 AM
Civic138's Avatar
Default Re: (theemaddhatterr)
as strange as it may sound, i'm not looking for certian amount of power. what ever i come out with in the end is what i come out with.
Old Nov 27, 2005 | 09:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic138 &raquo;</TD></TR><TR><TD CLASS="quote">as strange as it may sound, i'm not looking for certian amount of power. what ever i come out with in the end is what i come out with.</TD></TR></TABLE>that is strange..you should just slap a vtec head to that ****
Old Nov 27, 2005 | 10:01 AM
whiteef8's Avatar
that sounds like a good foundation, i mean you could always do more upgrades later, but why not do them now, so you dont have to crack her open later on down the road?? i like the way your thinking, i would just change a few things...definately a vtec head and higher CR pistons if youre staying all motor (you'll be pissed when you put all this money into the thing and its not even that fast due to the low CR, i'm running 10.4:1 Turbo Motor!!) and i would say balance/blueprint/crono treat the bottom end all up so you can rev her nice, and then some moderate headwork would sum it up...just my .02, dont gotsta listen, but the money to speed ratio in your project wouldnt be very good good luck, make sure you throw up some pics when you start getting her together, whatever the setup may be...
Old Nov 27, 2005 | 10:17 AM
Civic138's Avatar
Default Re: (whiteef8)
yea theres a place in nashville that'll completely blueprint,hot tank, and balance motors for like 250-300ish,so i'll prob hit that up.
i already have the motor tore down, but the build wont start untill Jan, i gotta have my suspension done before x-mas. i'm gonna start a progect log when i get done with the sup, so yea pics and info will be on that.
SilverWarrior
Mar 31, 2008 11:39 PM
clayton bigsby
Feb 11, 2007 04:15 PM
allmotor99lude
Jan 4, 2006 11:37 AM
Civic138
Nov 26, 2005 01:01 PM
Corinthians
Aug 27, 2004 07:06 AM
