what needs to be replaced when opening a transmission?
Old Nov 25, 2005 | 08:37 PM
92integraVTECgsr's Avatar
Default what needs to be replaced when opening a transmission?
I need to have my 2nd gear syncro replaced..
what else should i replace while im in there? like bearings, etc....
I want to put an ITR LSD in (my trans --> YS1 93 GSR)
Old Nov 25, 2005 | 08:58 PM
IN VTEC's Avatar
Default Re: what needs to be replaced when opening a transmission? (92integraVTECgsr)
I usually find myself replacing the following (in order of commonality):
1.) Input shaft bearing & seal
2.) Differential bearings & shim
3.) Axle seals
4.) Damaged shift forks
5.) 5th-Reverse gear synchro set (synchro's, synchro hub, synchro sleeve)
6.) Mainshaft bearing & shim/thrust washer
The first three are pretty common items to replace.
90lsvcrxva
Transmission & Drivetrain
Jun 24, 2012 03:05 PM
Cap'N Chronic
Jul 8, 2011 08:57 AM
95dxsir2
May 6, 2011 11:14 AM
stevenDAtegra
Dec 6, 2009 11:58 AM
civicturbo
Oct 14, 2005 08:52 PM
