Carbon fibre hood - latch problem
Old Nov 25, 2005 | 06:25 PM
RA73DR's Avatar
Default CF bonnet problem
sorry if this is the wrong section to post, so move if so.
i have recently put on my CF bonnet for my DC2R (AUSDM) quad headlight.
everything fits perfectly except for 1 problem.
my problem is that the bonnet will NOT CLOSE AT ALL.
the bonnet catches the latch but will not FULLY CLOSE.
ive tried everything placing bonnet onto the latch and pushing the bonnet down to close, but it just pops back up
i've searched various forums and one other person has said that the latch spring is too tight and needs to be loosened (as CF bonnets are way lighter thatn OEM)
so if anyone can help..
please do
Old Nov 25, 2005 | 06:33 PM
Reid's Avatar
Global Moderator
Default Re: CF bonnet problem (RA73DR)
So you've tried forcing it down with your hand but it won't close?
Old Nov 25, 2005 | 06:40 PM
RA73DR's Avatar
Default Re: CF bonnet problem (Reid)
yes.
im thinking that the spring latch is tensioned for the OEM bonnet which is much heavier that the CF bonnet.
The CF bonnet is just too light for the latch spring to catch and hold it.
Old Nov 25, 2005 | 07:25 PM
Dr Pooface's Avatar
I have to basically put all my weight over the latch and then jump on it for it to engage. Get hood pins.
Old Nov 25, 2005 | 08:03 PM
RA73DR's Avatar
problem fixed.
mods close.
Old Nov 26, 2005 | 12:13 AM
dk127's Avatar
Default Re: (RA73DR)
woa, just out of curiosity, can you explain what you did to fix the problem? i'm curious, and i'm sure some people will be too if they have the same problem someday down the road.
Old Nov 26, 2005 | 12:18 AM
Haleiwa-Brando's Avatar
Default Re: (dk127)
I was going to suggest using some kind of gasket or washer system between the hood latch and the hood it's self. Curious also how you fixed this problem.
Old Nov 26, 2005 | 07:56 AM
mugenracer's Avatar
Open the hood up and look at the latch on the lower panel, it should have 3 x 10mm bolts holding it in place. You need to loosen these and move the latch about until you get it to hook onto the hood clip correctly. I had to do this with my hood. When i fitted it it would close down and catch in the latch but sat about an inch high. By moving the latch down and all the way to the right it closed down perfectly. It helps to have someone with you to release the hood each time as its a pain having to walk around and release it from inside the car each time.
The latch is simple to get at in JDM ITRs but i'm not sure about US/Aus ITRs.
Old Nov 27, 2005 | 10:14 AM
raffiT78's Avatar
had the same problem, ^^^^^^ well explained, that pretty much what i did as well.
Old Nov 27, 2005 | 03:59 PM
RA73DR's Avatar
sorry for the late reply guys!
but as mugenracer said, the latch needs to be moved up.
loosen the 3 bolts of the latchand move latch upwards and tighten bolts again.
Old Nov 28, 2005 | 09:02 AM
SMZ GSR's Avatar
Default Re: CF bonnet problem (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">I have to basically put all my weight over the latch and then jump on it for it to engage. Get hood pins.</TD></TR></TABLE>
When I had my Integra I had the same issue with the CF hood that I had for 2 days. I removed hood before drilling for the pins I had, sold it and sold car
Old Nov 28, 2005 | 04:17 PM
mugenracer's Avatar
Default Re: CF bonnet problem (SMZ GSR)
When i fitted mine originally i was totally stumped as to what the problem was, i got out the measuring tape and thought maybe the CF hood latch was off centre or something, and i was about to take the hood off and put it up for sale thinking the front end of my car was fucked up somehow when i spotted the three bolts for the latch. After about 6 attempts moving the latch up/down/left/right it finally closed down perfectly. I was so freekin relieved but i forgot to mark the location of the latch for the stock hood so i'll have to do the same **** again when i refit the OEM hood when it comes time to sell the car
iggyc
May 7, 2008 01:22 PM
StolenTeg
Aug 23, 2004 09:50 PM
cannan
Dec 27, 2003 03:58 PM
2lua
11
Jul 8, 2003 08:13 AM
mugenintegra16
Dec 8, 2002 09:01 AM
