Problem with fogging windows
Old Nov 25, 2005 | 04:49 PM
Blazin Civic's Avatar
Default Problem with fogging windows
Jesus Christ integras suck for window fogging. I don't know if it is integras as a whole or just mine but as soon as the weather started to fall below 75 they fog like hell. Any fix for this? I can't drive around with my heat blasting all the damn time or the A/C.
Old Nov 25, 2005 | 04:50 PM
justin.parker's Avatar
Default Re: Problem with fogging windows (Blazin Civic)
happens to me too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Civic &raquo;</TD></TR><TR><TD CLASS="quote">I can't drive around with my heat blasting all the damn time or the A/C.</TD></TR></TABLE>
lol. Thats what I do to try to fix it. Either that or crack the windows. Dunno if there is a better fix.
Old Nov 25, 2005 | 07:19 PM
mike9571's Avatar
Default Re: Problem with fogging windows (justin.parker)
haha yea i have the same prob but its much colder....my only guess would be moisture in the car (mostly trunk)
Old Nov 25, 2005 | 07:22 PM
93_teg_CT's Avatar
Default Re: Problem with fogging windows (mike9571)
My problem is my heat works then 5 minutes later ice cold, then 5 minutes later boiling hot, thne ice cold... No idea what the problem is... And if leaks from my glove compartment... I'm just going to take my dash off next day off.
Old Nov 25, 2005 | 07:28 PM
mike9571's Avatar
Default Re: Problem with fogging windows (93_teg_CT)
yea mine too. when i come to a stop my heat gets cold then when i drive it gets like a heat gun. i have the same prob with water leakin under the dash ecspecially when it rains alot then i turn on the defroster.
Old Nov 25, 2005 | 07:34 PM
Naruto's Avatar
ehhhh..... all of you are describing something....that definitely needs to be looked at in terms of "leakage" or the temperature of the air coming in. My heater works fine no matter if I'm recirculating the air or if I'm pulling it in from the outside.
As far as the fogging goes....that's a normal thing that happens on every car. You probably don't notice it until you start driving anyway. And I'm sure you've overlooked that its the simple fact the some if not most of the moisture is coming from your breath ( believe it or not )
This is gonna sound stupid, but I tested that out one day by holding my breath while driving down a few blocks. After that, I drove like I usually do ( breathing wise ), let the windows fog up a bit. Turned off the defroster and tried it again. Yep....its your breath
Old Nov 25, 2005 | 07:36 PM
mike9571's Avatar
Default Re: Problem with fogging windows (Naruto)
im talkin about before i even get into the car its ridiculously fogged up
Old Nov 25, 2005 | 07:40 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">im talkin about before i even get into the car its ridiculously fogged up</TD></TR></TABLE>
If its during cold weather, that's normal, happened on every honda I've ever owned. To combat it though.... I use this stuff:
http://www.rainx.com/BB/default.htm
put your mouse on products, move it to windshield treatments, click....then click on anti-fog.
Of course, you'd have to clean your windshield first before applying it.
Old Nov 25, 2005 | 07:52 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
i have the same damn fogging problem. sometimes cracking the windows will help; other times it does nothing. sometimes its so damn cold that i have to constantly switch between heatvent and windshield.
but my heat doesnt get as hot as it used to though. last winter it would get so hot that i couldnt hold my hand in front of the vent for more than a few seconds lol.
Old Nov 25, 2005 | 08:01 PM
Naruto's Avatar
Default Re: Problem with fogging windows (benb18a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benb18a &raquo;</TD></TR><TR><TD CLASS="quote">sometimes its so damn cold that i have to constantly switch between heatvent and windshield.
lmao!!! I do the same thing...or I used to before I started using that rain-x stuff. It works pretty good and I recommend at least trying it out.
typeR564
Jul 8, 2008 12:38 PM
H0ndas g0 Vr00m
Honda Civic (2001 - 2005)
11
Jan 30, 2008 06:48 AM
schueytenten
Jul 10, 2007 03:36 AM
HiFi
Jan 25, 2006 12:11 PM
ITRNoah
Sep 16, 2004 11:15 AM
