how easy to tune ls/vtec?
Old Mar 12, 2002 | 10:21 PM
infamousALLMTR's Avatar
Default how easy to tune ls/vtec?
Im asking because im starting soon and will have 12:1 compresion with je pistons eagle rods and the block will be sleaved. So is there going to be a lot of tuning to get this beast running? Thanks
Old Mar 12, 2002 | 10:50 PM
rainforest's Avatar
Default Re: how easy to tune ls/vtec? (good Redracinghart)
tuning is more dependant on the cam timing and cams you have. like stock cams are alot easier to tune then aftermarket. so look more at the cams you have then the compression you have to tune the car. but tuning cam timing, can help with piston to valve clearance and other factors in high compression motors.
Old Mar 12, 2002 | 11:34 PM
Default Re: how easy to tune ls/vtec? (rainforest)
thanks... I was kinda worried about clearance since im going to have it sleeved and put bigger slugs in there.
Old Mar 12, 2002 | 11:48 PM
rainforest's Avatar
well if you had custom valve relifes for what cams you are running you will be ok. so basiclly you be ok.
Old Mar 13, 2002 | 09:26 AM
WAFFLES's Avatar
well with 12:1 compression you had better retard the timing!
Old Mar 13, 2002 | 10:24 AM
Quik Chris's Avatar
You really won't have to worry about it too much, you have a FPR, right? You'll need to bump the fuel pressure up a bit, but other than that, valve clearances will be fine. I ran 13:1 compression with no piston slap ever. That was a B18A1 w/ Civic R pistons and a GS-R head. The cam timing and fuel tuning will need to be done on a dyno with the Dyno's wideband O2 sensor and a V-AFC or comprible. What cams are you going to have in the motor? The tuning will be the same as if you were using any other block w/ engine modifications.
Rushintegra
Apr 28, 2013 08:37 PM
lude98SH
May 17, 2008 06:17 PM
unknown0001
Apr 24, 2006 08:00 AM
xpsonic
Feb 3, 2006 11:37 AM
X2BOARD
May 8, 2002 07:52 AM
