Adjustable FPR locations
I am installing my adjustable fuel pressure regulator and looking around for a good place to mount it
Curious where you guys with adjustable fpr's put em at?
the hood wouldnt close there and I wondered aboyt heat so i ended up mounting it here
now when I adjust this say for now stock is what 40psi
I do it at idle with the hose on right?
someone said to adjust it with the hose off?
Yes sir, 40ish with the vacuum off.
Man, if you aren't planning on making huge numbers, just have that SS mani braced on the bottom and it will work fine with no cracks. I know a couple of local guys who did it just to prove a point that the mani's can be run fine with just some added bracing. No need to spend the money twice when you have something that will work just fine with a little TLC.
