How can I tell if i still have my factory LSD?
Old Mar 12, 2002 | 09:33 PM
Lost Type R's Avatar
Default How can I tell if i still have my factory LSD?
Well ive been into an accident... and i think i had some front end problems with my R and they said there was some motor damage that they can fix... they are not specific with me but... what do i look for in my motor when i get it back? Before i know it.... they might scam me and put a gsr motor with an engine code imprinted b18c5. How can i tell if i still have my factory LSD? someone help me out....
Old Mar 12, 2002 | 09:36 PM
Type Goch's Avatar
New User
Default Re: How can I tell if i still have my factory LSD? (Lost Type R)
i think on the stock ITr tranny casing, it says J4D LSD or something like that. You'd know if its a type r motor or a GSR motor unless they put a GSR engine in it modified to fit the itr intake manifold on it.
Old Mar 12, 2002 | 09:38 PM
HybridKOOP's Avatar
Default Re: How can I tell if i still have my factory LSD? (Type Goch)
GSR head is stamped P72... Type-R is P30, can't fool you with that.
Old Mar 12, 2002 | 09:41 PM
Default Re: How can I tell if i still have my factory LSD? (HybridKOOP)
Thats the thing... i dont think its say J4D LSD anymore... i remember seeing that... but... its gone... either they jus replaced it with a new one... or they took it.. i dunno... kinda freaks me out there.... is there a way i can tell if i still have my LSD with how the car works? Just do normal take offs and see if its good... guess thats the hard way to find out heh..
Old Mar 12, 2002 | 09:44 PM
MK Ultra's Avatar
Get both of the front wheels off the ground, put the car in Neutral, and turn one of the wheels. If the one on the other side turns too, you have an LSD.
Edit: I mean turn as in spin the wheel, not turn like the steering would.
[Modified by MK Ultra, 12:45 AM 3/13/2002]
Old Mar 12, 2002 | 09:47 PM
Default Re: How can I tell if i still have my factory LSD? (MK Ultra)
ahh i see.... well i guess im gonna have to bring it to the shop after i get it back... thats my problem... i get too cocky with the people working on my R so i dont trust anyone that touches it...
Old Mar 12, 2002 | 09:55 PM
MrBite's Avatar
...Isn't that just the regular differential? Or does the LSD make them both turn the same direction, rather than opposite directions? I'm pretty sure any car will do what you described, not just LSD equipped ones...
Old Mar 12, 2002 | 10:07 PM
Type-Rare#1248's Avatar
i thought when you are in neutral, LSD doesn't work??
Old Mar 12, 2002 | 10:13 PM
MK Ultra's Avatar
Default Re: How can I tell if i still have my factory LSD? (MrBite)
I believe they should turn the same direction with an LSD, and the difference would be if somebody went and grabbed the other wheel it wouldn't just stop.
Now I'm not so sure...
Old Mar 12, 2002 | 11:23 PM
R-1303's Avatar
Doing that won't prove a daam thing..the car has to have pressure for the lsd system to work...you can't just check it by lifting the car off the ground..regular differentals will do that.....you can drop the cluth on the street and check for even burn out marks....but or take off the axles and if you can see through the bell housing you have lsd. good luck i'm the same way with my R
Old Mar 12, 2002 | 11:36 PM
let another type r owner drive your car...they could tell for sure!
Old Mar 12, 2002 | 11:39 PM
Reid's Avatar
Global Moderator
Default Re: How can I tell if i still have my factory LSD? (Type-Rare#1248)
Owning a type r does not mean you are mechanically inclined in any way or have any previous knowledge of cars for that matter.
Best way to do it is to look through the tranny as someone already said.
Old Mar 13, 2002 | 04:26 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: How can I tell if i still have my factory LSD? (Reid)
take both axles out and if you can see through the axle hole in the tranny it is lsd.if you can not see trough it, it is not
Old Mar 13, 2002 | 05:38 AM
Dr Pooface's Avatar
Default Re: How can I tell if i still have my factory LSD? (turbotypeR)
To check for lsd jack the car up and turn one wheel. The other should turn in the OPPOSITE direction.
Old Mar 13, 2002 | 09:53 AM
Mike K's Avatar
Default Re: How can I tell if i still have my factory LSD? (Dr Pooface)
make sure the car is in gear when you have the wheels off the ground.
turn one, and the other will turn opposite direction.
Old Mar 13, 2002 | 10:04 AM
Austin's Avatar
Just go do a friggin burnout...if you leave 2 solid strips you have LSD, if you leave 2 strips and then one strip disappears you dont. And it's easier to do a burnout with the e-brake pulled...
Old Mar 13, 2002 | 10:05 AM
Tommy_Gunns's Avatar
That's the sure fire messy way to tell for sure.
I wonder if all those other methods with spinning the tires work? Reading burnout marks does NOT work as I have seen many 2 wheel burnouts in cars without LSD's.
Old Mar 13, 2002 | 10:07 AM
cinq's Avatar
Just do a burn out...and check the tire marks...
Old Mar 13, 2002 | 10:15 AM
Austin's Avatar
Default Re: How can I tell if i still have my factory LSD? (Tommy_Gunns)
...snip....I wonder if all those other methods with spinning the tires work? Reading burnout marks does NOT work as I have seen many 2 wheel burnouts in cars without LSD's.
Yep, so have I...that's why you do one that's ~10 feet long with the e-brake pulled....and I know that this in not the healthiest way to find out, but it works.
Austin
Old Mar 13, 2002 | 10:22 AM
BSQ's Avatar
BSQ
Default Re: How can I tell if i still have my factory LSD? (Mike K)
Ok, I have a question. I have a '94 GS-R (I'm the original owner) and my wheels turn the opposite direction. I remember someone saying the the '94-'95 JDM GS-R equivalent (something like VTi) came with a LSD. Could it be possible that I have a LSD?
What direction will the wheels turn if you DON'T have a LSD? Same direction?
[Modified by BSQ, 2:31 PM 3/13/2002]
Old Mar 13, 2002 | 10:28 AM
Default Re: How can I tell if i still have my factory LSD? (BSQ)
I have a video clip of me launching with one wheel on dry pavement and the other wheel on loose gravel...you can hear me squawk the tires for about 10 feet, proof of LSD!
[Modified by BSQ, 2:23 PM 3/13/2002]
Old Mar 13, 2002 | 11:34 AM
reefer_bob's Avatar
Um... I have a '00 GSR, and I've peeled out for 20+ feet with the e-brake on... (It was for films sake) At anyrate, I left 2 very equal tread marks...
Reefer_Bob.
Old Mar 13, 2002 | 12:50 PM
DanYul's Avatar
New User
Default Re: How can I tell if i still have my factory LSD? (reefer_bob)
the easiest way that i can think of is if you just go ahead and paint a spot on the transmission casing.put it in an unusual place where they will not notice it i.e. in the back.
Old Mar 13, 2002 | 01:44 PM
sgT's Avatar
sgT
With an open diff or torsen lsd, the other wheel will turn in the opposite direction,
in gear or not. With a clutch type lsd, it will turn in the same direction.
if the car is in gear you would be trying to turn the engine along with the wheels.
Old Mar 13, 2002 | 04:54 PM
mugenracer's Avatar
Default Re: How can I tell if i still have my factory LSD? (sgT)
I have a JDM Si (GSR) and my car came with factory LSD, when the car is jacked up and you turn one wheel the other wheel turns the same direction too, on a car (my last teg) without LSD one wheel turned the other didnt
[Modified by mugenracer, 1:57 AM 3/14/2002]
Cesare1987
Sep 1, 2006 12:07 PM
hlee5363
Jan 13, 2006 10:42 PM
WH0R3nEF9
Mar 18, 2005 02:13 AM
jdub db8
Jul 26, 2004 10:55 AM
Propulsion
Mar 17, 2002 12:56 PM
