ITR HELP
Old Nov 25, 2005 | 10:37 AM
RIPPO's Avatar
Default ITR HELP
i have a ITR in my ek and my upgrades are i/h/e/ and an afc2. im still debating on turbo or goin ITB but for now what other mods can i do that will give me the best bang for my buck that i can still go with either set up. please give input
thanks
Old Nov 25, 2005 | 11:05 AM
saver's Avatar
easy
just get a fuel rail, filter, and a fpr. then spark plugs, cables, ignition moduel, and cam gears
that set up will work either way with turbo or na
good luck
Old Nov 25, 2005 | 10:15 PM
RIPPO's Avatar
Default Re: (saver)
will that make a signifigant increase in power output?
wat about cam gears or anything else like that?
thanks alot bro
Old Nov 26, 2005 | 10:18 AM
saver's Avatar
it will make a diffrence but not a huge one tho but its worth it and its a set up for a turbo to. o and add the cam gears to thats really good to. if you going to go turbo then i go with some gsr cam gears. its easy to tune with a turbo more i hear.
good luck.
Old Nov 26, 2005 | 11:46 AM
RIPPO's Avatar
Default Re: (saver)
what if i didn't boost it? wat cam gears would be best ? im lookin at toda's or spoon or jun's but still doin lots of research on it.
thanks for your input
Old Nov 27, 2005 | 06:28 PM
saver's Avatar
Default Re: (RIPPO)
to tell you the same for wat i have learned and seen the cam gears or the same but i could be wrong. i would go with jun. wat car is it going in
Old Nov 28, 2005 | 10:01 PM
RIPPO's Avatar
an EK
civic_saints1
Jun 15, 2007 03:08 PM
Sir-Boost-Alot
Oct 26, 2005 02:00 PM
jsprelude
Oct 7, 2004 05:48 PM
Civic92Turbo
Jul 21, 2004 05:20 AM
redboost10
Oct 30, 2003 01:36 PM
