plug on a B18a
Old Nov 25, 2005 | 10:29 AM
CBURKE's Avatar
Default plug on a B18a
What is this green plug on the back of the B18a? Will I be using it in my Civic Si?
it's next to the oil filter.
Old Nov 25, 2005 | 10:32 AM
krazie1's Avatar
BANNED
Default Re: plug on a B18a (CBURKE)
try searching bro next time
that is going to be the knock sensor
Old Nov 25, 2005 | 10:35 AM
CBURKE's Avatar
that's what I thought it was, but the Si did not have a knock right? so I guess this will not be used.
Old Nov 25, 2005 | 10:44 AM
RCautoworks's Avatar
Default Re: (CBURKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">that's what I thought it was, but the Si did not have a knock right? so I guess this will not be used. </TD></TR></TABLE>
What ecu are you using ?
Old Nov 25, 2005 | 10:46 AM
CBURKE's Avatar
i'll be useing the one that came with the motor, 91 ls. not sure what the #'s are.
Old Nov 25, 2005 | 10:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">i'll be useing the one that came with the motor, 91 ls. not sure what the #'s are.</TD></TR></TABLE>
Ok, so you will be using a knock sensor.
Old Nov 25, 2005 | 10:48 AM
CBURKE's Avatar
does the harness have one already? I don't remeber seeing one on my si harness.
Old Nov 25, 2005 | 10:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">does the harness have one already? I don't remeber seeing one on my si harness.</TD></TR></TABLE>
No, you will have to add it. Really hope you did your research before you attempt this, sounds like you haven't
Old Nov 25, 2005 | 10:51 AM
CBURKE's Avatar
I was told that the 90 to 91 ls motor was pretty much plug and play in the si other then the motor mount and links. It's no biggie if I have to add it, I was just wondering.
Old Nov 25, 2005 | 10:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">I was told </TD></TR></TABLE>
Careful on who you listen to, it kind of is plug and play but there are some things that need to be changed and added.
Old Nov 25, 2005 | 10:59 AM
CBURKE's Avatar
well kust reading on here, every one is saying you should just be able to pug it right up. I have not seen anything about this yet. But I guess I will just have to wire up the knock and call it a day. Or is there another ECU I can use?
Old Nov 25, 2005 | 11:00 AM
You know what though, I thought something was weird in the picture. The knock sensor is usually higher up on engine blocks. That sensor is either for the cooling fan or oil light. How many prongs is there ?
So I searched, the b18a does not come with a knock sensor on it.
Old Nov 25, 2005 | 11:02 AM
CBURKE's Avatar
I need to get a closer pic, but the oil is next to it. I read somewhere that the GSR had a knock so I guess i'm good to go.
Old Nov 25, 2005 | 11:03 AM
CBURKE's Avatar
I just remembered doing it on my mitsu and yeah they don't even look like that. The look more like a oil sensor.
Old Nov 25, 2005 | 11:04 AM
jack_attack's Avatar
that motor doesnt have a knock sensor that plug goes to your dash for the oil pressure
so if you have an si or are wired for mpfi that motor is just a matter of plug n play
Old Nov 25, 2005 | 11:05 AM
CBURKE's Avatar
no, the oil plug is next to that.
Old Nov 25, 2005 | 11:10 AM
Then its the radiator fan sensor.
Like I said, be careful who you listen to.
Old Nov 25, 2005 | 11:11 AM
CBURKE's Avatar
lol, thanks for your help.
Old Nov 25, 2005 | 03:11 PM
hizroyalty's Avatar
yeh definately no knock its for ur oil pressure
Old Nov 25, 2005 | 04:05 PM
trrbl1bmx's Avatar
if its one prong then its oil light(oil pressure gauge if you have it) and if its 2 prong then its radiator fan switch. Another way to tell is unscrew it from the block and see if there is oil on the sensor!
Old Nov 25, 2005 | 04:30 PM
rbjeepthing's Avatar
Default Re: (ilovemyef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemyef9 &raquo;</TD></TR><TR><TD CLASS="quote">if its one prong then its oil light(oil pressure gauge if you have it) and if its 2 prong then its radiator fan switch. Another way to tell is unscrew it from the block and see if there is oil on the sensor!</TD></TR></TABLE>
If the head gasket is gone it's possible to find coolant on the plug which would give hime the wrong answer again.
Old Nov 25, 2005 | 04:50 PM
fourthgenhatchB17's Avatar
Default Re: (rbjeepthing)
It appears to be the oil temp sensor thats only used on the integras (92-93 only i think) to turn the fan on or off if the OIL TEMP gets too high. Can u get a better picture? Is the block a 92-93?
Knock sensors never came on the LS motor, thats a no brainer.
EK FLY
Nov 12, 2006 10:20 AM
ek_b16
Jun 29, 2005 09:17 PM
eLUDEnu
Oct 5, 2004 08:07 AM
tradesalot
16
Sep 19, 2004 09:07 PM
DumpedSi
Aug 14, 2003 01:28 PM
