JDM SRS steering wheel question!!??? did search
i was told that the JDM srs steering wheel will just plug and play on a 96-01 integra but will not on 94-95
but i heard about probs with getting the return for the turnsignals not working properly
im looking to put this on a 97 and wanna know if it will just plug and paly and everything will work with no probs???
install was a breeze with my 96. Took 45 minutes total. 40 minutes to get the ***** to disconnect the airbag harness while the airbag is sitting in my lap. oh ya and 5 minutes to swap. Dont for get to have a torx sex ready.
yes but did it just bolt right on and plug right in?? cause people say that you might have trouble with the connector and having the turnsignal return no work properly
the connectors are the same, make sure your wheel its a dc wheel, not ek. Theres no practicale way to tell, so when you order it you need to feel confident that its labled correctly.
I broke one of the plactic pegs that the wheel slides on to. Im not sure if this caused my turn signal to not fuction properly, or if the wheel is just set up for "opposite" turns. Anywho it works, the simple nudge of your finger turns it off.
The wheel has a racing design to it, not your ordinary integra steering wheel by any means. id sacrifice having to manualy do turn signals any day.
Cruise control is lost, not an option.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rod64 »</TD></TR><TR><TD CLASS="quote">So if i were to get that jdm srs steering wheel, there is no way i could still have cruise control?? and i would still have no problems using my turn signals right???</TD></TR></TABLE>
You can use cruise all you have to do is remove the module from the oem wheel and connect the wires and mount it. your turn signals will work sometimes it will not cancel though but well worth it
ok so after all your saying is buy an integra dc2 itr srs wheel and it bolts right on and plugs right in a 96-01 integra no probs. except the turn signals
how long should it take to do est. ? anything i should or need to do in the process??
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BETNCORT »</TD></TR><TR><TD CLASS="quote">How would they mess up your turn signals?</TD></TR></TABLE>
I have the JDM SRS wheel on my 98 ITR and the turn signal turns off easier turning to the right than they do turning to the left. I have to usually turn off the left signal due to this unless I am making a very sharp turn. I have gotten used to this, it becomes second nature after driving with it like that for a while. The wheel feels so much better than the stock USDM one that the turn signal thing is not that big of an issue.
floatfisher
May 16, 2008 09:28 AM
tremor86
Nov 14, 2004 06:52 PM
mixmastabob
May 7, 2003 07:16 AM
