cometic head gasket/arp head bolts
Old Nov 25, 2005 | 01:49 AM
DB1_559's Avatar
Default cometic head gasket/arp head bolts
im going to change mine soon to be on the safe side for my future mods .have any of u got this on ur car and what is the best for a d16z6 its going to be n/a.yeah and the arp head bolts don't look stock how would i install it.any help will be greatly thanks. if u ask why is because the motor got a lot of miles and im planning on doing a full tune up/rebuilt . thanks jdmboi86
Old Nov 25, 2005 | 03:28 AM
JDMlyfestyle's Avatar
Just get the stock Cometic or OEM headgasket. Not 100% but i believe the D16y8 headgasket is the same and its cheaper
ARP"s are a great investment on any engine.
Old Nov 25, 2005 | 06:28 AM
1995Civic's Avatar
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Just get the stock Cometic or OEM headgasket. Not 100% but i believe the D16y8 headgasket is the same and its cheaper
ARP"s are a great investment on any engine.</TD></TR></TABLE>
I have to agree. If your car is stock and you're only planning on NA (Idk why) your best bet would be OEM headgasket w/ ARP headstuds. Stock headstuds cannot be re-used. You dont need any other hg for this type of build.
Old Nov 25, 2005 | 07:17 AM
BiG Chris's Avatar
i run a cometic HG but thats only because im boosting if you plan to keep that motor na and just run it hard get the stock gasket the arp bolts i would say is good just to have
Old Nov 25, 2005 | 07:22 PM
DB1_559's Avatar
Default Re: cometic head gasket/arp head bolts (jdmboi86)
about the arp head studs/bolts does it comes like the factory bolts instead of just the long screws and bolts
Old Nov 25, 2005 | 07:27 PM
littlegreenb18's Avatar
arp's are studs not bolts, they screw into your block(basically just a threaded stick), then you put nuts on the studs(is there any way to put that that doesn't sound like a sexual innuendo?)
Old Nov 25, 2005 | 07:38 PM
DB1_559's Avatar
how would u screw it on the block do i need special tools or can i tighten down with the nut in place untill tight thats the part that get's me
Old Nov 26, 2005 | 10:14 AM
BiG Chris's Avatar
you start the threaded stud by hand and then put 2 of the nuts on that stud and lock them together then you can tighten the stud from there.
Old Nov 26, 2005 | 02:26 PM
Default Re: (BiG Chris)
actually the stud only needs to be hand tight, the nuts are what puts pressure on the head(there we go with the sexual innuendos again )
Old Nov 26, 2005 | 02:52 PM
DB1_559's Avatar
kool that was the parts that got me
DrkHrse
54
Feb 10, 2013 03:55 AM
yfz
Dec 12, 2010 07:13 PM
ketchup!
Apr 10, 2009 04:20 PM
draperj09
14
Mar 28, 2007 09:50 PM
dornon13
Dec 17, 2004 01:11 AM
