problem with aftermarket fuel line
Old Nov 24, 2005 | 09:56 PM
racekar711's Avatar
Default problem with aftermarket fuel line
Has anyone used an aftermarket fuel line with your stock fuel iintegra gsr fuel rail?
i have to use one becasue when i use the stock fuel line on the ITR IM/ITR CAI the fuel line rubs hard against the intake tubing.
so i bought an aftermarket one with 2 banjo fittings, which are a couple of MM thicker than the stock banjo fittings. The fuel filter banjo fit fine, its the banjo fitting that goes on the stock fuel rail that im having a problem with. There are 2 washers, 1 on each side of the stock banjo fitting, if i try to use the 2 washer on the new aftermarket banjo fitting it strips the fuel rail end nut thing. So i bought another fuel rail end nut and took one of the washers out (the washer between banjo and stock fuel rail) which gave me like a mm. But that was enough to tighten it so that fuel wouldnt leak. Do you think that is ok, if im not using that washer.
or does anyone else have any susggestion? i cant use stock fuel line it seems unless i turn the stock fuel line at an angle and not fit it between the 2 things at the end of the fuel rail that hold the banjo fitting in place?
Old Nov 25, 2005 | 11:13 AM
racekar711's Avatar
uppppppppppppppppp
Old Nov 25, 2005 | 02:41 PM
kchungb17a's Avatar
Default Re: (racekar711)
You need that crush washer to seal the line. W/out it you will leak fuel. What setup do you have? Why don't you just find an LS/ITR fuel line and use that? Fits like a glove.
Don't forget to CAREFULLY check for fuel leaks before you go running it. It would suck to have your car blow up!
Old Nov 25, 2005 | 03:08 PM
racekar711's Avatar
is the LS fuel line longer?
Old Nov 25, 2005 | 03:10 PM
racekar711's Avatar
setup is skunk2 IM with gsr TB and ITR CAI
stock gsr fuel line rubs
Old Nov 27, 2005 | 07:48 PM
kchungb17a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racekar711 &raquo;</TD></TR><TR><TD CLASS="quote">is the LS fuel line longer?</TD></TR></TABLE>
Yes it is. This is what I used when I put the ITR IM on my GSR w/a PR3 head, because the origianl fuel line was rubbing my intake arm too.
Old Nov 28, 2005 | 01:18 PM
racekar711's Avatar
bought one thanks
Kdx
Nov 10, 2018 07:41 AM
EK FLY
Jan 6, 2006 05:04 PM
Mr. Anderson
Feb 21, 2005 08:01 AM
