gsr into 90 si
Old Nov 24, 2005 | 09:37 PM
xcivichatch90x's Avatar
Default gsr into 89 si
hey guys im swapping my gsr into my 89 si out of my wrecked 94 ex and i had a couple questons...im gonna run it obd0 for now... and im wondering if i should remove the butterflies from the manifold or leave them unhooked? or if it will even make a difference...also im wondering if the sensors on it are the same as putting a b16inbto an ef....basically just looks like i lengthen some plugs and everything should be fine...and last i have an obd0 ls distributor that i have to cut a lobe off to make it fit but do you guys think that will work? thanks for the help guys...
Brandyn
Modified by xcivichatch90x at 6:51 AM 11/25/2005
Old Nov 24, 2005 | 10:17 PM
RCautoworks's Avatar
Default Re: gsr into 89 si (xcivichatch90x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcivichatch90x &raquo;</TD></TR><TR><TD CLASS="quote">also im wondering if the sensors on it are the same as putting a b16inbto an ef</TD></TR></TABLE>
nope, search a little .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcivichatch90x &raquo;</TD></TR><TR><TD CLASS="quote"> if i should remove the butterflies from the manifold or leave them unhooked? </TD></TR></TABLE>
You should look into an aftermarket manifold, like blox.
Old Nov 24, 2005 | 10:29 PM
Kidnkorner's Avatar
Default Re: gsr into 89 si (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">You should look into an aftermarket manifold, like blox.</TD></TR></TABLE>
Or Skunk2
Old Nov 25, 2005 | 02:10 AM
Default Re: gsr into 89 si (Lynx Bus Type R)
i did a search but couldnt find exactly what i was looking for... a new manifold really isnt in the budget as of right now...but will be in a short while...just wanna get the car out of my moms garage and to my house...shes a little upset about that
Old Nov 25, 2005 | 05:07 PM
anybody else?
henryf2si
Honda Civic (2006 - 2015)
Nov 21, 2007 09:32 AM
Luong
Oct 25, 2007 11:01 AM
damn_import_culture
May 1, 2007 12:55 PM
aka
Sep 21, 2005 11:46 AM
hatchback_al
33
Aug 19, 2003 09:06 PM
