maintenance light flashes.
almost due for maintenance. If you want to turn it off look under the steering wheel cloumn and under the dash there is a little green button encased in a black casing. Push that for a good 5 seconds and it'll clear the maintenance light
Under driver dash is a green button. Reach under right side of steering wheel and feel around. Mine is a green square button. Hold that down while turning the key to the on position. Hold it for about 5 seconds. It should flash and then will go away.
It comes on every 7500 miles i think.
Audio28
Nov 17, 2002 09:56 AM
