type r ecu in 98 gsr
Old Mar 12, 2002 | 08:21 PM
b18c-93's Avatar
New User
Default type r ecu in 98 gsr
a friend of wrecked his 98 typer and kept the ecu well i have it in my 98 gsr for allready two days and then a check engine light came on of code 1 and then code 45 which is too lean or too rich and one is 02 sensor so what can i do too fix that i have a fuel pressure regulator set at about 50 psi
Old Mar 12, 2002 | 08:51 PM
rainforest's Avatar
Default Re: type r ecu in 98 gsr (93gsb16a)
it cant be ecu related because its 100% ok to run the type r ecu on the car.
Old Mar 12, 2002 | 08:58 PM
b18c-93's Avatar
New User
Default Re: type r ecu in 98 gsr (rainforest)
a while bach a friend of mine used his ecu at the track due too not having his ecu upgraded and had the same code but everything else was working just fine
NosCivic01
Aug 16, 2010 06:31 PM
kornerk12
Mar 19, 2008 05:37 PM
TyPe_R_GuY
Oct 9, 2003 07:01 PM
Trac226
Jan 4, 2003 04:14 AM
jdmEKhb
Dec 13, 2002 10:39 AM
