need tip for cams for B16A1
Old Nov 24, 2005 | 06:42 PM
RaCk's Avatar
Default need tip for cams for B16A1
I need a little more out of the B16A1 currently within my Rex while i build the B20. But im unsure what cams i should go for. I currently have a Skunk2 intake manifoil and Injen exhaust mani. (4-2-1)
Any tips on cams between the range of 300-700 bucks?
edit : did search. Didnt get any wiser.
Old Nov 25, 2005 | 03:04 AM
Shirk's Avatar
Default Re: need tip for cams for B16A1 (RaCk)
How did you get the Skunk2 manifold to fit? I had too much problems with idle and coolant, so I had to sell it
Regarding cams, I have no idea how cams designed for the B16A(2) will fit/work in our A1 head. I guess parts from the US are made for the A2 in 99.999999% of the time. Personally, in the furure, I will only buy from European companies just to be sure
As for now I know of two companies that make cams for our engines. http://www.kentcams.com and http://www.catcams.be . Found them through http://www.kollevold.no
Old Nov 25, 2005 | 03:10 AM
UNKNOWN_MEMBER's Avatar
Default Re: need tip for cams for B16A1 (Shirk)
ctr
Old Nov 25, 2005 | 04:44 AM
Autoworks's Avatar
Default Re: need tip for cams for B16A1 (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">ctr</TD></TR></TABLE>
all the way You can get the CTR intake cam for $240, and a new cam seal from Honda for $7.
Very nice gain, OE quality, and about 1hour to install
Old Nov 25, 2005 | 10:41 AM
RaCk's Avatar
I delivered the original intake and the skunk 2 to Polly Motorsports and he welded over the "flens". I dont recall the english word for it. But i can see you are Norwegian as well.
I have another Skunk 2 lying around if you are interested.
Old Nov 25, 2005 | 11:36 AM
TehMoonRulz's Avatar
Default Re: need tip for cams for B16A1 (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">all the way You can get the CTR intake cam for $240, and a new cam seal from Honda for $7.
Very nice gain, OE quality, and about 1hour to install</TD></TR></TABLE>
Not from a US dealer though?
Old Nov 25, 2005 | 12:18 PM
Suck my DX's Avatar
Default Re: need tip for cams for B16A1 (TehMoonRulz)
if ur gonna be swapping the intake you might as well swap the exhaust as well.... u can find a good set of IN and EX cams from an itr/ctr on here for like 300 bux...
if u want a little more power without having to upgrade ur valvetrain the skunk 2 stg 1 cams are also good for a lil more power than the ctr cams.....anything larger and it will be necessary to swap out you LMA...
Old Nov 25, 2005 | 01:37 PM
RaCk's Avatar
im just looking for a little more power. i will be happy with 170-180hp total.
Old Nov 25, 2005 | 03:26 PM
Professor15's Avatar
well how much $$ do you have to spend? if your max is like 700-800. get a 2 or 1 layer thin head gasket to bump up compression. See how much you can get a valve job at the machine shops around your way for and ctr or itr cams which are usually 300 bucks. After that save up for tuning.
Old Nov 25, 2005 | 04:29 PM
RaCk's Avatar
i could stretch as far as 1000. But then i would have to postpone the B20 for a month. heh.
Anyone know of a place to buy skunk cams?
Egpower88
Feb 14, 2009 07:32 PM
VVV
Dec 21, 2008 02:39 AM
2k.civic.si
Apr 17, 2007 06:24 PM
