can you fit these tires on a crx?
Old Nov 24, 2005 | 05:56 PM
Panoply's Avatar
Default can you fit these tires on a crx?
i was looking into the bfg drag radials 250/50/15 on some 15x7 wheels on the front?. i was thinking of something smaller and cheaper for the rears but still using the 15x7 rim. the car has h&r race springs. just wanted some experience from the guys who have run/tried to run this size tire. i don't mind altering the fenders to run such a big tire, just wondering if i have to before i order them. thanks.
Old Nov 24, 2005 | 06:19 PM
b18ccivics's Avatar
Default Re: can you fit these tires on a crx? (Panoply)
i hope that is a mistake 205/50/15 is what you need, if you plan on altering the fenders to fit some tires then go ahead and get some real slicks, i cut 1.800 60' in a full interior ex coupe with a 22-8.50-15
Old Nov 24, 2005 | 06:23 PM
Panoply's Avatar
Default Re: can you fit these tires on a crx? (b18ccivics)
actually it was a mistake, but i meant 225, not 250. and id like to get the 225 if they will fit.
Old Nov 24, 2005 | 06:38 PM
mr. carpenter's Avatar
i've run them on eibachs and had rubbing under autocross and track conditions but not daily driving. i actually cut the inner edge of the fender into small tabs and hammered them flat and it went away.
Old Nov 24, 2005 | 06:44 PM
Panoply's Avatar
Default Re: can you fit these tires on a crx? (mr. carpenter)
would you say it was a worthy enough trade off for the better traction and having rubbing issues?
Old Nov 24, 2005 | 11:12 PM
yes. the fender actually took a chunk out of one of my tires. where i bent the fenders in is'nt even visible.
Old Nov 25, 2005 | 12:08 AM
elrandeeto's Avatar
what is your setup , that u cant get enough traction with 205's
Old Nov 25, 2005 | 12:57 AM
shorbie621's Avatar
Default Re: can you fit these tires on a crx? (elrandeeto)
he didnt say he had traction problem, he was just wondering if he can run those tires on his rims =/
Old Nov 25, 2005 | 01:02 AM
elrandeeto's Avatar
Default Re: can you fit these tires on a crx? (shorbie621)
he hasnt bought them yet , imo why get a bigger heavier tire if you dont need it and might have rubbing issues
Old Nov 25, 2005 | 06:40 PM
Panoply's Avatar
umm 300 whp? once the block is built the sky is the limit.
Old Nov 25, 2005 | 06:43 PM
Panoply's Avatar
and i think, because im lowered as low as i am, ill just wait to get some slicks and just run 205/50/15 for now.
BryceMcCulloch
Dec 18, 2018 06:38 AM
ilikejesus
Mar 23, 2009 02:52 PM
wfocrx
Apr 4, 2007 11:17 AM
mdmitch2
Jul 15, 2005 09:41 PM
travis
17
Jun 12, 2002 03:21 PM
