HONDA PRELUDE OWNERS: Have you had this problem
Old Nov 24, 2005 | 05:48 PM
ddupre's Avatar
Default HONDA PRELUDE OWNERS: Have you had this problem
My wife has a 2000 prelude and our headlights are extremely scratched up. Has anyone had this problem? What could have caused it? Where can we get new ones? Thank you so much in advanced.
DD
Old Nov 24, 2005 | 05:49 PM
inn0vated's Avatar
ive seen writeups before of how to fix it. it just involves some sanding. some people use a dremel and lightly buff the lens. then they use a polishing compound along with some wax to clean it back up again.
Old Nov 24, 2005 | 05:51 PM
prelude1897's Avatar
Default Re: HONDA PRELUDE OWNERS: Have you had this problem (ddupre)
What you can do is try waxing them with a good compound type substance. If that doesn't work, you can wet sand them, then polish them up. I've had to do this with several sets of headlights. They come out pretty good in the end
Old Nov 25, 2005 | 09:35 AM
maks's Avatar
Default Re: HONDA PRELUDE OWNERS: Have you had this problem (prelude1897)
I've had the same problem, check this thread, at the very bottom, I posted my solution, worked like a charm
https://honda-tech.com/zerothread?id=1394776
Old Nov 25, 2005 | 10:45 AM
OEM_ASSASSIN's Avatar
I have heard that if you sand them, they will turn yellow over time.
Old Nov 25, 2005 | 12:32 PM
maks's Avatar
Default Re: (OEM_ASSASSIN)
I sanded them to get rid of the nasty yellow you mentioned. Sure you may have to repeat this procedure once a year to keep them looking pretty, but I think it beats the hell out of buying new headlamps!!!
RA61825
Sep 30, 2009 12:21 AM
RAMMINRAM
Sep 14, 2009 08:00 AM
khronicboy420
Jul 15, 2009 06:10 PM
SCNetTek
Mar 2, 2005 05:12 PM
