y8 manifold on b7
Old Nov 24, 2005 | 03:29 PM
Stevorh's Avatar
Default y8 manifold on b7
Has anyone ever put a y8 manifold on a b7? I tried doing this but it didn't bolt up and the fuel pressure regulator is on the opposite side as well as a different type. Any advice? Thanks.
Old Nov 24, 2005 | 03:51 PM
Civic Racer X 7's Avatar
you mean the bolt holes are different
fpr shouldnt matter just extend the vacuum hose to it
Old Nov 24, 2005 | 04:57 PM
EG8R's Avatar
Default Re: (Civic Racer X 7)
Why wouldn't it bolt up? What year is the mani from? I think I may know why if it's what I'm thinking.
Old Nov 25, 2005 | 10:38 AM
Stevorh's Avatar
Default Re: (skelly ed666)
the fpr is a different design on the y8. The manifold is a 99-00 one. The holes line up, but the block gets in the way because the manifold needs to be grinded down.
Old Nov 25, 2005 | 04:02 PM
Stevorh's Avatar
Default Re: y8 manifold on b7 (Stevorh)
bump
Old Nov 25, 2005 | 04:35 PM
mike93eh
Guest
Posts: n/a
i beleive you need a 96-98 manifold.
Old Nov 28, 2005 | 09:02 PM
Stevorh's Avatar
Default Re: (mike93eh)
so the 96-98 is the one that will bolt up? Not the 99-00? So nobody has put a 99-00 ex intake manifold on their d-series?
Old Nov 28, 2005 | 09:41 PM
FalkenSiR's Avatar
Default Re: (Stevorh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stevorh &raquo;</TD></TR><TR><TD CLASS="quote">The holes line up, but the block gets in the way because the manifold needs to be grinded down.</TD></TR></TABLE>
What?
This manifold does fit your block.
Old Nov 28, 2005 | 10:40 PM
ek99's Avatar
Default Re: (fast88std)
(STEVORH) Its not a direct bolt on. You will have to trim the top of the manifold flange to clear the head. Or you can grind the head a little. Just use the y8 fuel rail with your old injectors and it will solve you fpr problem. The only other thing i had to do was drill the holes for the iac valve on the back of the manifold. Kinda tricky, but it works.
Old Nov 29, 2005 | 09:15 AM
mike93eh
Guest
Posts: n/a
Default Re: (ek99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 &raquo;</TD></TR><TR><TD CLASS="quote">(STEVORH) Its not a direct bolt on. You will have to trim the top of the manifold flange to clear the head. Or you can grind the head a little. Just use the y8 fuel rail with your old injectors and it will solve you fpr problem. The only other thing i had to do was drill the holes for the iac valve on the back of the manifold. Kinda tricky, but it works.</TD></TR></TABLE>
the 96-98 you dont have to do that.
Old Nov 29, 2005 | 09:18 AM
SE7EN3S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stevorh &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone ever put a y8 manifold on a b7? I tried doing this but it didn't bolt up and the fuel pressure regulator is on the opposite side as well as a different type. Any advice? Thanks.</TD></TR></TABLE>
What is a B7?
Old Nov 29, 2005 | 09:23 AM
Luserkid's Avatar
Default Re: y8 manifold on b7 (SE7EN3S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SE7EN3S &raquo;</TD></TR><TR><TD CLASS="quote">
What is a B7?</TD></TR></TABLE>
D15B7 from 92-95 DX, LX
Old Nov 29, 2005 | 09:28 AM
SE7EN3S's Avatar
Default Re: y8 manifold on b7 (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
D15B7 from 92-95 DX, LX</TD></TR></TABLE>
Gotcha... I was thinking he ment a Y7 and was wondering how the hell he was having problems
GiMpInThaCiv
Oct 31, 2006 01:58 PM
Irishweird00
Mar 27, 2003 08:45 AM
fastcrxsi90
Dec 24, 2002 03:51 PM
fastcrxsi90
Dec 24, 2002 10:03 AM
96hbdx
Jul 11, 2002 08:01 PM
