92-95 D16z6 distributor wiring....
Old Mar 12, 2002 | 07:09 PM
vsual's Avatar
Default 92-95 D16z6 distributor wiring....
does anyone have a picture of where the white wire from the 92-95 d16z6 distributor go to when repinning it to the 1991 SI connector??i dont know which white wire to connect it because...the SI has 2 white wires....thanks in advance.
Old Mar 12, 2002 | 07:34 PM
StorminMatt's Avatar
Default Re: 92-95 D16z6 distributor wiring.... (vsual)
The SI plug has two white wires. But if you notice carefully, one is bigger in diameter than the other (and, for that matter, bigger than all the rest of the wires). Connect the SMALL white wire on the 1991 plug to the white wire on the 1992-1995 plug. Connect the larger white wire on the 1991 plug to the yellow/green wire on the 1992-1995 distributer.
Old Mar 12, 2002 | 09:46 PM
Blown90hatcH's Avatar
poof.....
[Modified by Blown90hatcH, 10:56 PM 3/12/2002]
Old Mar 13, 2002 | 04:09 AM
vsual's Avatar
Default Re: 92-95 D16z6 distributor wiring.... (Blown90hatcH)
thats the picture i was looking for...i could'nt find it..i knew i seen it before. thanks.
[Modified by vsual, 5:10 AM 3/13/2002]
EJ1 wilcox
10
Mar 8, 2011 03:15 PM
BoRiCuA
18
Jun 21, 2004 12:15 PM
SickRevHrdTeg
Aug 18, 2002 04:26 PM
