how can i wire an SI gauge cluster to work on my DX and have it all work????
Old Mar 12, 2002 | 07:06 PM
civicracer1993's Avatar
Default how can i wire an SI gauge cluster to work on my DX and have it all work????
i got a SI guage cluster from a 4 dr civic. it was automatic but the gauge cluster has a tach and speedometer and gas and all that on it.. well how can i wire it to my DX so that it all works ? including the tach? 2 plugs r the same but there is like 2 extra that i dont have???
thanks
mike
Old Mar 12, 2002 | 07:12 PM
vsual's Avatar
Default Re: how can i wire an SI gauge cluster to work on my DX and have it all work???? (civicracer89)
what color connectors do you have left??
Old Mar 12, 2002 | 07:17 PM
kyler's Avatar
dunno man.. i threw an Ex cluster in my dx and it plugged right in fine (sedan though)... if you got it from a yard i would look and see if you can swap it for a manual one once they get one..
Old Mar 12, 2002 | 07:32 PM
Aphrodavid's Avatar
Default Re: how can i wire an SI gauge cluster to work on my DX and have it all work???? (kyler)
guage clusters from 88-91 are all interchangable, meaning they all bolt in the same way and have the same connectors. i wouldnt recommend using an auto cluster with a manual and vise versa. just because the auto has different sensors and can give false ecu codes. if you have a manual tranny, i would use an 88-91 cluster from a manual si, ex, or lx(youll have a cruise control light, but it doesnt matter).
Old Mar 13, 2002 | 04:37 AM
virginia_dude's Avatar
Default Re: how can i wire an SI gauge cluster to work on my DX and have it all work???? (DX-R)
They all bolt in but are not fully interchangeable without a little work. 88-89 are plug and play within the same 2 years, and 90-91 are interchangeable within the same 2 years, you can swap between those groups with some minor wiring changes. I have a 88 EX sedan cluster in my 89 DX so I have a tach with a 7,200 RPM red line big woop. I know the ZC has a 8,200 RPM redline, take yellow paint and convert the redline between those 2 points to yellow. Junkyard I went to charges $25 for clusters, you pull. from the yard no guarantee.
Old Mar 13, 2002 | 04:41 AM
EP3_05's Avatar
Default Re: how can i wire an SI gauge cluster to work on my DX and have it all work???? (virginia_dude)
ZC has a 7200 redline and depending on the ecu a rev limit in between 7500 and 8000.
Old Mar 13, 2002 | 04:45 AM
Default Re: how can i wire an SI gauge cluster to work on my DX and have it all work???? (91civic)
You are right, I made the mistake. It is 7,200 rpm. May bad. I think the EX had a 6,500 rpm redline now that my brain is working better, Spin a ZC to 8,200 and you ARE going to have some serious problems.
Old Mar 13, 2002 | 12:42 PM
well i plugged it in today and the plugs match up but there is still the tach and the gas and stuff that need to b hooked up seperately.. also when i turn on my high beams the gas needle goes down??? why??something is wrong.. also if i just take the tach and and run that then how would i hook it up ??
mike
MrExclusive
Feb 20, 2010 08:18 PM
jdmDRIFTER
13
Jan 13, 2007 10:24 PM
Nicaraguense13
Nov 28, 2006 02:32 PM
powerslave
10
Sep 28, 2006 03:31 PM
pK1spooled
Oct 2, 2004 01:24 PM
