Bare block to running block...
Old Nov 24, 2005 | 06:39 AM
JDM00SI's Avatar
Default Bare block to running block...
So im pretty much having Benson assemble and build my bare ls block. What am i going to need to get it in running condition, ex. sensors, oil pump, water pump, thromostat? the tube that goes from the thermostat...etc.
Which sensors do i need? What are these parts called? I wish i could get a pic of the block, but it wont be back untill end of January.....
things i know i need
- oil pan plus oil pan gasket with all studs w/ drain plug
-oil pump w/ bolts
-water pump w/ bolts
- crankshaft with the little key they call it?
- headgasket
-brackets to mount engine
which sensors do i need? w3hat else do i need.
Old Nov 24, 2005 | 06:40 AM
JDM00SI's Avatar
Default Re: Bare block to running block... (JDM00SI)
bump
Old Nov 24, 2005 | 09:00 AM
95gsrcrx's Avatar
ok if your going to be running obd1...
the you'll need:
oil pressure sending unit
crank seal (flywheel side)
if your putting the motor into your 2000 civic then the mounts that you have for your si...will work. but you should look into getting a replacement bracket for the driver side mount. because that jelly mount wont be strong enough for the high horse power setups. now im no pro but i put together my own motors (three motors) and i just wanted to help...hope thats what i achieved with this post...
Old Nov 24, 2005 | 10:21 AM
JDM00SI's Avatar
yea either way im getting anew drivers side bracket due to the fact its a b18a1 not a b18b1....
i will be running obd 1.
what do you mean by jelly mount side bracket? do they make aftermarket ones?
im using hasport motor mounts.
Old Nov 24, 2005 | 12:31 PM
JDM00SI's Avatar
Default Re: (JDM00SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI &raquo;</TD></TR><TR><TD CLASS="quote">yea either way im getting anew drivers side bracket due to the fact its a b18a1 not a b18b1....
im using hasport motor mounts.</TD></TR></TABLE>
Old Nov 24, 2005 | 08:57 PM
JDM00SI's Avatar
bump
Old Nov 25, 2005 | 09:20 PM
JDM00SI's Avatar
bump for mmore replys
Old Nov 27, 2005 | 05:43 AM
JDM00SI's Avatar
thanks for the help.
civic-r11
K Series
Sep 19, 2010 06:45 AM
AutoFabProductions
Dec 7, 2004 05:13 PM
Odiedogcx
Sep 20, 2004 01:42 AM
onetwothree
Mar 30, 2003 03:00 PM
baonest
Aug 3, 2002 02:24 PM
